Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 08-12-2009
JerryD's Avatar
JerryD JerryD is offline
Dedicated Member
JerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond reputeJerryD has a reputation beyond repute
Reaper Mixing Question
Hi,
I use reaper. There seems to be tones of effects. HEre are my questions.
1. What effects in reaper are relaly good ones?
2. What effects should I use on vocals?
3. What effects are meant to be run on the entirety of the song. I mean on the master area?
You were at school and you were pimply and no one wanted to know you. You get into a group and you've got thousands of chicks there. Eric Clapton
Old 08-12-2009
d.bop d.bop is offline
Senior Member
d.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond repute
Hey! Welcome to REAPER
Honestly...all of them! There are a TON of JS effects, but if you're new to REAPER (or recording) I would stick with the stock "Cockos" plugins in the beginning, but then again it's always fun to explore and experiment with different plugins!
This is totally subjective to the type of material you are mixing. Some people like some distortion, some like LOTS of reverb, some don't, some use pitch correction, I've even used a bit crusher on some vocals.
Normally what gets used on vocals is compression and a slight bit of reverb. Though, some prefer delay over reverb. The stock "reaverbate" is a great reverb plugin. There is also "reaverb" which is convolution-based.
Again, that depends on what you're mixing. Most often, people don't touch the master bus. If something needs to be fixed, you're better off fixing it in the mix itself (although, some things come in handy. Like tape or vinyl emulation, or an obvious effect that will be applied to the entire project.)
If you're mastering your own projects though, you might want to try ReaComp and the JS effect "eventhorizon2" limiter to bring the levels up. Just don't go crazy. Too much compression/limiting will make your mixes fatiguing, and sometimes even annoying to listen to.
Honestly, there is no magic formula to this thing called "audio engineering." Just use your ears, experiment, and tweak until it sounds good to you. Every mix is different and will be treated differently. There are some great resources over in the forums at reaper.fm including the popular thread "Why Do Your Recordings Sound Like Ass?" and of course the user manual and Geoffrey Francis's other great REAPER books.
I hope that helps!
Old 08-13-2009
JerryD's Avatar
Dedicated Member
I hope that helps!
Excellent. That provides me with a lot of information. I'll get back with you after I read the information you provided. Thanks a lot!!!!!
Old 08-14-2009
theCKWilliams's Avatar
theCKWilliams theCKWilliams is offline
Junior Member
theCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond reputetheCKWilliams has a reputation beyond repute
thanks for the q&a!
Mixing Down in Reaper Somelsewhere Don't Fear The Reaper 5 07-24-2009 07:57
Reaper Question... solaris1982 Don't Fear The Reaper 3 08-05-2008 07:15
Reaper Question danny.guitar Digital Recording & Computers 12 04-03-2007 01:49
Reaper Question danny.guitar Digital Recording & Computers 18 12-29-2006 10:04
Reaper Question sixways Digital Recording & Computers 30 11-10-2006 10:17
