Reaper vs Audacity
I am a competent Audacity user and I don't particularly want to switch except I could use better MIDI and plug-in capability.
Anyone switched from Audacity to Reaper and if so, what are the benefits if any? Thanks |
Yes, actually. I find that for most mixing purposes, I like Reaper much better.
Reaper is better for monitoring your levels; there are a lot more level gauges, so you can tell exactly where things are clipping. Reaper edits non-destructively. When I did a CD in Audacity, there were at least two occasions where Audacity delted all my data files for no apparent reason. Reaper only deletes all my data when I explicitly tell it to. Reaper has better plugins and effects. There are a lot more, they're usually better made, and there seems to be much more community support for them. Plus, Reaper comes with the JesuSonic plugin programming language, which is pretty sweet. (I've automated some of my favorite Audacity tasks into a single effect I can turn on with one click.) That being said, I still use Audacity for some tasks. After I finish a track in Reaper, I'll run it through Audacity's volume effect since that's a much quicker and easier way to turn the whole track's volume up to just below clipping. When I need to do quick, simple changes to an audio file (adding one effect that both systems have, deleting some dead air, etc.) I'll often use Audacity since it's a little faster for those kinds of tasks. All in all, I highly recommend upgrading to Reaper. Audacity has its uses, but Reaper is usually better. |
Download it and try it yourself.
Only YOU can determine if a sequencer fits YOUR brain and workflow. |
Thanks for the input. Some of the things you mention do sound like an improvement. I think I will download it and give it a try.
WRT to brain and work flow, I have Ableton Live which came with a piece of gear I bought. Ableton is the antithesis of what fits my brain and work flow! |
I downloaded Reaper a few days ago to see if the analog conversion to digital sounds better then Audacity. So far I like Reaper better as far as the conversion factor is concerned. I think I will buy the full version when I can and do away with Audacity once and for all. I do all my work in analog and dump it to digital to put on cd. So far so good.
It's easy to stand out in a crowd when the level of competence is so low. |
stick audacity in REAPER's right click menu as one of the external editors, then you will have the audacity pencil tools and stuff you are already familiar with and the learning curve wont hamper you from getting work done
DrummyQ VST New! Kompound Drums Vol 1 Sample Building Kit REAPER Merchandise REAPER Chat |
Thanks, I'll give it a try.
Another advantage of Reaper is that you get to pick this guys brain sometimes!
| Audacity help | darthmaul_55117 | Digital Recording & Computers | 4 | 01-28-2009 11:10 |
| audacity? | m_von_lie | Recording Techniques | 14 | 03-16-2008 11:29 |
| audacity | hrwmusic | Digital Recording & Computers | 11 | 02-27-2006 20:22 |
| Anyone use Audacity? | Neotrix | Digital Recording & Computers | 4 | 03-06-2005 09:25 |
