Should I bother with this compressor?
Probably an obvious question, but if you dont ask etc....
Ive got an analogue set up,fostex R8 and a fostex 358 mixer, which i was talking about with a music friend the other day. It turns out he has an old fostex 3070 compressor/limiter, that he has now given me. ![]() Now, ive never used a compressor before, and im not totally sure what they do, I was under the impression that they made the signal more even, making the quiet bits as loud as the loud bits. Anything else? Are they really that essential? Im always hearing people mention compression, but having only recently started recording with my own set up, ive not had the opportunity to ever use one? Are they worth using? Does it really make a noticable difference? |
Depends upon what your recording and what kind of sound your after. A bass guitar might need compression for example in a rock band to keep it from falling out of the mix.
I too have a Fostex R8 and Fostex 350 (im assuming you meant 350 not 358), and also have considered getting the Fostex 3070. Apparently it can add some nice color to your recordings but unfortunately I also heard it can be quite a noisy compressor. Nevertheless you got it now and should definitely at least try it. Play around with it and don't be too put off if you can't achieve the most desirable results in the beginning. Given that you have never used a compressor, there is quite a learning curve, first learning how it works and what each knob does then figuring out how to get a good sound out of it. Until you get down the basics and get some experience, you won't need a better compressor. One last thing, i would probably incorporate the compressor during your tracking process and not mastering because the R8 already generates enough hiss so if you wish to minimize hiss, use it before you record the signal to tape. |
Thanks for the reply.
Seeing as you have the same gear as me, ill take advantage of your knowledge..... ![]() the compressor has phono and jack ins and outs on both channels. So, lets say you were recording a bass, would you run it thrrough the effects loop on the fostex ? or in line like a guitar stomp box? |
Here are a few good on-line sources about compression and compressors.
http://www.tweakheadz.com/compressors.htm http://web.archive.org/web/200605060.../compbasc.html http://www.recordingwebsite.com/rwti...ive/rw34r.html http://www.recordingwebsite.com/rwtip/archive/rw68.html http://www.analogrules.com/secret2.html http://www.soundonsound.com/sos/dec0...d5c2f226113d0c http://www.soundonsound.com/sos/jan0...d5c2f226113d0c ![]()
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
Thanks for taking the time to post those links. Ill give them a good look at and hopefully Ill be a bit clearer.
For bass, i actually mic the bass amp as well but i'm not sure if that's common practice professionally but if you were to plug it into the line, i would plug the bass guitar into the input on the mixer then run the compressor through the effects loop, this is especially the case with microphones because you (I) would prefer using the preamp on the mixer to boost up the mic volume then the gain knob on the compressor because the mixer will probably give a cleaner signal. |
Yeah, sorry I made myself sound a bit more stupid than I actually am in that post.
I didnt mean in line to the mixer, more like using it as you would any guitar effect, then using a mic or DI as normal, or using it linked to the mixer. Ive seen the effects send return, and the individual controls on each channel for the effects level, but so far ive not had any effects to try, and a compressor is probably the worst one to try first.... ![]() Ill have a go, and report back. if you have more than 1 rack mounted effect, do you just plug them in series? |
| sorry to bother again.. but.. | ace516 | MP3 Mixing Clinic | 0 | 04-24-2005 22:56 |
| Does This Bother You..... | smellyfuzz | Songwriting, Singing & Vocals | 17 | 09-04-2003 06:01 |
| should i even bother? | erichenryus | Studio Building & Display | 16 | 12-13-2002 12:31 |
| can i bother you? please? | jeap | MP3 Mixing Clinic | 8 | 08-31-2002 12:39 |
