Old 08-01-2009
Victory Pete's Avatar
Victory Pete Victory Pete is offline
Thinking outside the box
Victory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond repute
Unhappy Overshoot of RTZ on MS-16
I have been making tape tension adjustments on my MS-16 and since I have started tweaking it misses Zero. I have the tensions set to factory specs with a Tentelometer. If I increase the FF and RW tensions a bit it seems to improve. I understand the whole concept of dynamic servo braking, the servo motor behind the leading servo motor must have less torque so it will put tension on the tape and provide the braking resistance. I finally realized the actual mechanical brakes have nothing to do with slowing down the tape. They are for keeping tension on the tape and tension arms when the tape is stopped, like a parking brake.
VP
Old 08-01-2009
dodgeaspen's Avatar
dodgeaspen dodgeaspen is offline
Liquid Nite Recording
dodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond reputedodgeaspen has a reputation beyond repute
Hey Pete, I was reading your post and was curious on the ms-16 is it supposed to stop directly on 0? My 38 will RR and FF until it gets close to 0 it may stop a few feet before. I was just wondering. BTW, how are the studio walls coming?
It's easy to stand out in a crowd when the level of competence is so low.
Old 08-01-2009
Yes they are suppose to slow down then stop right on zero after you hit RTZ. The RW and FF tension is not set right. It is a very sensitive adjustment. I managed to fix one of my TSR-8's before that would overshoot rewinding to zero, I tweaked the RW tension pot and after a few tweaks it stopped perfectly everytime. I should be able to work on your Test Tape Clone soon. The studio is not finished yet but it is squirrel proof!
VP
Old 08-01-2009
dodgeaspen's Avatar
Hey man no hurry. I'm just glade you have no more unwanted 4 legged guests in the studio.
Old 08-02-2009
sweetbeats's Avatar
sweetbeats sweetbeats is online now
Reel deep thoughts...
sweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond repute
Dunno if this relates but I had an issue on my 58 where the brakes were not adjusted to hold strong enough and on a FF wind the takeup reel would coast a bit too far allowing enough slack for the tension arm to come to its unloaded stop and the transport would go into stop mode. The brakes certainly play a role.
Are you sure your Tentelometer is correctly calibrated, and describe how you are doing it...I had some real headaches doing the tensions on my 58 and I never got them right before I cooked some of it but I learned a bunch of particulars on calibrating the Tentelometers particularly from Beck at the time.
Old 08-02-2009
I dont know about the 58 but on the MS-16 and others the mechanical brake bands around the reel hubs have nothing to do with the actual slowing down of the tape in FF or RW. The tension in FF and RW is maintained by the difference in torque between the 2 servo reel motors. The Tentelometer is a brand new T2 H20 ML from Tentel, the calibration kit is backordered but I imagine it must be accurate for now.
VP
Tascam 48 Counter and RTZ problem Rufer Analog Only 11 09-15-2008 12:27
TASCAM 424 MKII Problem...RTZ button not working...=/ Joshua J. TASCAM User Forum 0 06-25-2008 23:09
Rtz 9762 !! Tonio The Rack 0 02-02-2006 10:34
Tascam 388 RTZ & counter problems unarmedman Analog Only 8 01-16-2006 10:46
CDs that overshoot 0 dB?!!! sucram Digital Recording & Computers 4 06-29-2001 12:44
