Old 07-30-2009
lo.fi.love's Avatar
lo.fi.love lo.fi.love is offline
Autodidact, Analog Addict
lo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond reputelo.fi.love has a reputation beyond repute
DIY Alignment and Calibration
I'm interested in aligning and calibrating my machines, and I'd like to know where to start on this. I've read the calibration article in the second Tape Op book and it gives what seems to be a good overview, but I'd like to have the opinions of people here.
So from what I understand, the following items are necessary:
1. MRL test tape
2. The manual for the tape machine being calibrated
3. Oscilloscope for doing azimuth adjustment
4. An oscillator
What else? Is this a difficult procedure for someone who is technically apt?
Old 07-30-2009
Victory Pete's Avatar
Victory Pete Victory Pete is offline
Thinking outside the box
Victory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond repute
Lightbulb Hands On!
1. MRL test tape
4. An oscillator
A good AC voltmeter that can read down to 20 mv and has a bandwidth of 150Khz. You will also need an assortment of adapters and cables, various hand tools. You also must have patience and some free time. I have been aligning all my machines for months now. There is a trial and error learning curve, but the results are worth it. You will gain a complete understanding of your machines that will help you in the long run. I just recently bought a tentelometer and 2 spring scales which let you know your tape tension is correct, you dont need them but at some point you will want them.
VP
Old 07-30-2009
ofajen ofajen is offline
Daddy-O Daddy-O Baby
ofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond repute
1. MRL test tape
4. An oscillator
You may occasionally want to check the bias frequency, to make sure it is close enough to the spec'ed value, so a frequency counter can also come in handy.
I have also found it handy to have plenty of unbalanced "mults" in a patchbay, so I can tie the oscillator output to every input on the machine all at the same time and not have to patch cables. I think I have eight of them in one old hard-wired 1/4" bay, each with four jacks tied together, so if I need to feed eight inputs, I can tie four of them together and then plug the oscillator in and then out to all the record inputs.
Cheers,
Otto
Old 07-30-2009
sweetbeats's Avatar
sweetbeats sweetbeats is offline
Reel deep thoughts...
sweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond repute
There are other ways to do the azimuth...I've used a freeware PC-based oscilloscope plugin that gets it good enough. I have a scope now so I'll be using that. There are other ways that I've used to but they are really for being more in a pinch.
You can get cheap or free tone generators for the computer too, or download test tones from analogrules.com.
The meter is the stickler. Needs to be a true RMS meter and have at least a rated bandwidth of 20-20,000Hz. Yeah, 150kHz is nice for checking the bias frequency, but that's $$$.
We'll help ya. Been through the exact same road as you.
Old 07-30-2009
jedblue's Avatar
jedblue jedblue is offline
beep beep beep beep beep
jedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond reputejedblue has a reputation beyond repute
I've been assembling all my stuff over the last couple of months...
1). Test tape (320 nWb/m) for my decks.
2). AC Millivoltmeter out of Hong Kong off eBay - not that expensive and really really useful (and you may find a 2nd hand one locally of eBay or Craiglist). I got one of these dual channel jobbies;
http://cgi.ebay.com.au/PRECISION-DUA...3286.m20.l1116
3). I've got a Wavetek 134 function generator with sweep;
4). and tonight I pick up my oscilloscope on the way home so I should be properly set.
I can already do the alignments on the Otari and the Revox with the test tape, the millivolt meter and the 1K & 10K internal oscillator from the Otari by setting up the Otari 1st and using that to set the PR99. They are all aligned for +4db but I'm contemplating dropping the PR99 to -10db (although it is output gain adjustable using the output gain pots). The Otari is switchable between the two. I also followed the alignment instructions in the manuals I've got for the machines rather than a generic process.
The plan is not only to keep on top of the alignments but to do all the maintenance like Cory does. That's why the oscilloscope, function generator and solder station / sucker and all those little tools as well.
I've also found a source of cassette alignment tapes (not cheap) and I've got one of those coming so I intend to use that to go through and check all my various cassette decks and adjust as neccessary / possible.
The millivolt meter is turning out to be a very very useful device. I've been using it (and the Otari's output calibrated 1k oscillator) to check the metering accuracy on lots of my pieces of kit. Otto's point about his cables is also the way to go. I've started to make my ones up myself, (might have to check out Otto's point about the frequency counter too).
All good
Geoff
Old 07-30-2009
lo.fi.love's Avatar
Wow, this is all very good information. I'm interested in getting my hands on an oscilloscope, an oscillator, and a voltmeter now.
I thought I was cruising along... thought I wasn't going to buy any more stuff for a long time except for maybe some more 1/2" tape. Guess I was wrong... ha ha ha!
Old 07-30-2009
evm1024's Avatar
evm1024 evm1024 is online now
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
I've always liked Tektronix equipment. My summer job was building scopes for them when I was in high school and I later worked in a Tek wafer fab.
So I tend to get old tek hardware for my test setup. Just what I grew up with. And this stuff is outstanding even for 30 year old stuff (kinda like my decks)
It can also be boght off ebay for not too much and the manuals are very good.
Here is what I use mostly:
Tek 465 Dual trace 100 MHz scope - I bought this broken for $75 and fixed it.
TM504 mainframe (free)
DM501 4.5 digit meter (free - broken but I fixed it)
DM502 3.5 digit meter (Free - and it was working!)
DC503A 110 MHz universal counter ($35 off eBay Working)
PS501 tracking power supply (Free!)
Signal generator (generic aerospace - $40)
This setup covers almost anything. The signal generator is levels which means that it keeps a constant output as you change the frequency. The DM501 reads has 4.5 digits to you can measure -10 dB as 0.3160 V and it gives true RMS to over 150 kHz.
I suppose that I'll get a FG501 function generator to replace the signal generator some day.
REgards, Ethan
In Sunny Vancouver ..... (Washington)
Old 07-30-2009
jedblue's Avatar
Impressive stack Ethan, how much'd the eggs cost?
Geoff
Old 07-30-2009
evm1024's Avatar
1K Silver Member
Geoff
5 dozen for $5.99 on sale at Winco.
That crate holds parts very nicely!
--Ethan
Old 07-31-2009
sweetbeats's Avatar
Geoff, what's your source for cassette test tapes?
Jeff, like Ethan told me long ago, one step at a time. And have fun!
It is rewarding and valuable to be able to maintain your own equipment. That's really what got me started is I was concerned nobody was going to care for it like I would...the analog equipment garners such little repect in general.
I personally wouldn't worry about a scope yet, but that's just my opinion. I've really just recently gotten to the point where it is necessary (for recalibrating my DX-4D's...another Ethan/Cory joint venture...I'm like the lab gopher...he's the brains).
A used Fluke 83/85/87 DMM (for example) will get you far as well as a couple freeware software utilities and that along with the test tape and some way to attenuate the test tones coming off the computer and you can cal your deck.
I made my own spring scales to do the brakes...a set of feeler guages from an auto parts store are good and get yourself an insulated "tweaker" (screwdriver)...Harbor Freight has sets of them for cheap.
Old 07-31-2009
I've had a Fluke DMM for a while now and it's OK, but I also have an HP analog AC voltmeter and I find the needle on a scale to be much quicker and more intuitive than red LED digits. YMMV.
Cheers,
Otto
  #12
Old 07-31-2009
fstrat76 fstrat76 is offline
Newbie
fstrat76 is on a distinguished road
I may also be interested in the DIY maintenance.
What freeware did you use?
Also, what's a reliable source for finding an alignment tape for my 38, through Tascam directly?
  #13
Old 07-31-2009
miroslav's Avatar
miroslav miroslav is offline
Cosmic Cowboy
miroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond reputemiroslav has a reputation beyond repute
Here is a great PC-based oscilloscope/analyzer application...freeware.
Visual Analyzer
http://www.sillanumsoft.org/
I use it for setting up my decks…works great.
One thing though about the azimuth...
I've heard a some folks say that unless the heads are virtually brand new and/or have relief grooves cut...then don't mess with any physical head alignments, since the tape has already begun to cut a microscopic groove into the head based on its path (even if it’s not visible)...and once you start physically aligning a grooved head then you stand the risk of messing with your tape path because the tape could end up riding slightly out of the already formed groove (or the beginnings of a groove) and then all the other calibrations will be that much more difficult.
I just picked up a new ¼” half track, an Otari MX5050BIII-2, so I did a full check and physical alignment of the heads, and from this point on I will just be doing electronics alignments until it's time for new heads or a head relap.
Again...this is just what I've heard from a few guys in the past...but when you think about it, it does make sense NOT to mess with a head that's already "settled in".
I would love to hear some more opinions on this...
miroslav
miroslav
http://www.miroslavmusic.com
"If it sounds right, it is right!"
  #14
Old 07-31-2009
Newbie
Is there another way to test head alignment without the test tape right now, just to see if I even need an alignment?
I think I saw in the 38 manual that its fine if you just continue use the sync head for record and playback, all tapes are only playable on that machine using sync.
My understanding from the manual is that misaligned heads will cause a drop in dB (on the repro head). Of course, my understanding is limited. My original thought was to use a daw to check for phase cancellation of a tone played back on the sync head vs the repro head.
Just a (cheap) thought.
Any other ways?
  #15
Old 07-31-2009
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow
Almedio in Japan bought out all the TEAC Test Media business. It's a little tougher to match their catalog numbers to what you actually need, so some 1:1 correspondence to them for clarification might be necessary. It wouldn't hurt to start by referencing the old TEAC alignment tape part number, and work from there.
I bought a TEAC alignment tape or 2 before TEAC sold it off. I have the calibration tape for a 2x speed Portastudio and a 1x speed Portastudio,... by actual part number. I also councilled a little with a TEAC rep on the various part numbers of cal tapes, and was told that several of the different part numbers would be nearly compatible, so you might only need one, then use it on the similar decks. Say, if the 246 manual calls out a specific TEAC test tape , but the 688 calls out a different number,... logic tells you that each one should be similar enough to the other to just buy one to use on both.
It was expensive, though. On the same price level as a reel MRL test tape, or thereabouts./DA
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
  #16
Old 07-31-2009
miroslav's Avatar
Cosmic Cowboy
Record a test tone, and then compare the levels going in VS the playback levels. That's a simple/basic check, but it only reveals one aspect of electronic alignment...there are other steps that a calibration tape will be needed for.
Using the Rec head for playback will not give you as good quality as the standalone PB head...the Rec/sync is mainly a cue/reference signal for your tracking.
miroslav
miroslav
  #17
Old 07-31-2009
Well, John Stephens carried this idea to it's logical conclusion on at least some of his machines... the heads were carefully aligned and then glued in place. No physical adjustments were needed or really even possible unless you were doing major work on the heads.
I've made occasional adjustments to azimuth (at least to check, especially when a machine gets moved or heads are relapped and then optically aligned first.) I haven't noticed those adjustments causing problems in doing the electronic alignment.
OTOH, probably there is little risk in leaving the heads in place if the machine isn't moved and the heads aren't pulled or relapped, etc. The exception would be if the head mounts and adjusters aren't as secure as they should be.
Cheers,
Otto
  #18
Old 07-31-2009
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Good stuff so far.
Welcome to miroslav!
You definitely need a calibration tape from MRL or TEAC. Unfortunately that is one costly thing you can’t do without.
I listed a few things in the threads below some time ago
http://homerecording.com/bbs/showpos...81&postcount=9
http://homerecording.com/bbs/showpos...52&postcount=6
Radio Shack keeps moving their links around (How do they stay in business ?)
http://www.radioshack.com/search/ind...tId=&kw=22-811
And here is another O-scope
http://www.dsp4swls.de/download/oszilight.zip
Can't find Winscope anymore. The people at archive.org should be shot for making robots retroactive. IMO, they either have it archived or they do not. Once they have it (which they did in this case) they should keep it. To freeze time... that's what they're for. It's down right un-American!
/Rant (sorry)
I've only used PC-based O-Scopes for a few years now. They do the trick for tape deck alignment.
One thing to add about using sync or repro heads. It depends on the design of the machine. As a rule the repro head is better, but Tascam broke that rule with a few of their decks. Machines like the 38 and 48, use the same part number for both sync and playback heads. So, you don’t get the same advantage by using the repro for playback as you would with a machine that has a specially designed Repro head.
In a private studio environment your calibration will hold for a long time. When getting a new/old machine I recommend doing a full align (usually needed, but not always). After that you will just check it maybe every six months to see that it is still right on. I go for three years never having to tweak anything.
Yeah, about azimuth... I just go by the scope. If it stays within spec you don't have to mess with it all the time. The surface of the head will change with wear, so it may need a bump now and then over the long term.
~Tim
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
  #19
Old 07-31-2009
miroslav's Avatar
Cosmic Cowboy
Thanks Beck!
I have that Radio Shack digital multi-meter (or one very similar to it)...it also has the option to read signals as dBm, so it saves some time.
While I didn't actually glue the heads, I did drop some nail polish on each of the adjustment screws...though like something someone else once said...they've never seen a screw turn itself, even during transport!
But I guess a good bump or two could make 'em twitch a little.
I only put the nail polish on the screw heads 'cuz I can be somewhat anal about stuff like that!
But I'm the only one touching my studio gear for the most part, and I'm pretty gentle, so I don't expect the screws/heads to ever move physically once they are set.
I'll be doing my 16-track soon, which has seen some use, but even that deck is pristine, and will probably only need a touch-up on the electronics.
miroslav
miroslav
  #20
Old 07-31-2009
jedblue's Avatar
Now that's good to know Dave. I've had a look at their web site and they have what I was looking for.
Geoff
  #21
Old 08-07-2009
QuadMusic QuadMusic is offline
Newbie
QuadMusic is on a distinguished road
It's available at http://madan.wordpress.com/2006/06/2...-winscope-251/
PC
  #22
Old 08-20-2009
lo.fi.love's Avatar
OK, I asked a question about voltmeters, I got this response:
Please pardon me for being confused, but I don't know how to look for such a thing. "How do I search for a voltmeter with these specifications?" is a question that I can't answer.
Can someone point me in the right direction by posting a product link? I'll really appreciate it.
  #23
Old 08-20-2009
I have an HP 403B. It gets the job done.
Otto
  #24
Old 08-20-2009
sweetbeats's Avatar
IMHO 150kHz bandwidth is overkill for doing an alignment. Jeff, what I think you want to look for is a voltmeter that is rated from 20Hz to 20kHz with limited error within that range. Any of the Fluke 83/85/87 meters will do nicely for that and are pretty plentiful on the used market. Any of the analog meters mentioned above will do too, but if you get a meter that has a rating in the "audio" band range it'll work for you too. You can download manuals for the Fluke meters on their website to confirm bandwidth.
If you are having bias issues then having higher bandwidth is important because bias tone is typically 100kHz, 150kHz or even 250kHz. But if you are having trouble there then its time to have a scope and such. That's my limited personal experience.
BTW everybody evm1024 turned me on to TrueRTA, a freeware analyzer/scope/meter for PC...the coolest freeware program like this I have ever seen. It'll help folks that are on a budget pinch for sure or don't need such utilities frequently and can't justify springing for hardware counterparts.
Yep...and others followed suit. 58 is the same way. Only need met and advantage gained on such sytems is having the repro head there for on-the-fly bias adjustment and other diagnostics. It becomes little more than a convenience feature...nice one though.
  #25
Old 08-20-2009
evm1024's Avatar
1K Silver Member
try jameco
Jameco sells a number of meters. This link is to the spec sheet of one of the meters that they resell (they have a nice selector as well)
You can see the spec under the "AC volts accuracy" heading 5% for the 10 to 20 KHz range....
http://www.jameco.com/Jameco/Product...DS/1581214.pdf
I'm not recommending this meter (it does look nice) it was just the first one that I get the specs from.
Regards, Ethan
Here is the interactive selector:
http://www.jameco.com/webapp/wcs/sto...%20Multimeters
80-8 alignment hatbeardglasses Analog Only 2 12-20-2007 03:20
Time alignment / Phase alignment. Picks and Audio examples. tarnationsauce2 Mixing / Mastering 14 03-13-2007 10:38
Noise Reduction DIY >not gated< DIY? orson198305 The Rack 12 06-21-2006 18:54
calibration hotel2tango Analog Only 3 09-15-2005 12:38
alignment help FALKEN Newbies 3 01-28-2005 16:05
