Back to Analog - Questions
My Tascam 38, which I originally purchased with an M-35 mixer in 1985, I sold in 1994. I needed 16 tracks at the time and bought 2 black-face ADATs and a Tascam M-2600 24 channel mixer.
After recording with the ADATs for a bunch of years, I went all digital with a Tascam FW-1884 hooked up to various Macs running Logic Pro. Great stuff considering the space constraints I now have. But something was missing. Maybe it was the sound, maybe the fun factor, I don't know. So last month I bought a Tascam 38 off of eBay. It was in mint condition. I'm sure to no ones surprise, the unit arrived damaged in shipping. The feet were bent or pushed into the bottom, the capstan belt was disintegrated and rubber was all over inside. The left hub was low. It took a beating. Sad. Luckily, the pushed in foot at the bottom pushed into an empty area on the frame and did not damage the circuit boards or other frame parts. So I got the unit adjusted and its now in working condition. I baked some old tapes (Ampex 456 and 3M 226 and 996) and they played perfectly on the unit. I transferred some tracks into my DAW and was absolutely amazed at the sound quality I got even 20 years ago. I mean, its comparable or maybe even better than some of the stuff I did on ADATs or all digital. Now I want to hook all my analog gear back up and start using it as well as my DAW and such. I cleaned up my M-35 and I'm thinking about tracking and hookup scenarios, and even thinking about digging out the huge M-2600 24 channel because it has phantom power (which I need). The FW-1884 also has phantom power and I suppose I could route the insert send to the 38. Or I could buy a phantom power supply and hook up directly to the M-35, then on to the 38. What I'm wondering is what others have done to maximize use of the analog equipment and tie it into a DAW. I don't have the cash for anymore outboard analog gear so for more than 8 tracks I'll be mixing in the box with Logic Pro I guess. Does anyone have suggested hookups? Track on the 38, transfer to DAW, or track to DAW and mixdown on the 38? Or Both? Should I bother setting up the monster M-2600 or just stick with the M-35 (or FW-1884). I'm looking for your ideas or how you might go about it. Also, I'm looking at getting some new ATR tapes. Does the 38 need to be re-calibrated for these tapes? I've learned a ton already from this forum and looking forward to getting back to analog! Thanks! --Mike |
Yes you'll need to recal for ATR tape and AFAIK the 38's bias amp circuitry will not properly bias ATR tape. I say "properly" as many use that tape anyway but Teac did not design the 38 or other 1/2" 8-track decks (and others) of that era for the bias requirements of that tape. Any reason you aren't looking at the equivalent tape for which Teac designed the deck (i.e. RMGI SM911)?
The 38 is not a mixdown deck, and if you track to the DAW you are likely to miss out on all the good analog "stuff". I suggest tracking to the 38 and either mixdown or dump to the DAW. Also if it were me I'd be getting out that 2600 and doing side-by-side comparisons between all three pre's and see which one fits best. |
I never noticed any noise difference in mixes (hiss or otherwise) between my 38 and Roland digital workstation.
Yeah, I thought about bringing that M-2600 out. I really don't have much room for it. I thought the M-35, by driving it harder, might give me more of that warmer sound as I read the M-2600 has a more clean or pristine sound. Probably opinions of course, but the M-2600 is 10 or more years newer than the M-35. Doesn't hurt to give it a try. |
The ATR vs. RMGI battle seems to be more of a Ford vs. Chevy argument than anything else. Some would argue that ATR makes a better product; I have no opinion on this. Personally, I use SM911 because all of my decks were designed to use Ampex 456. Your deck, the 38, was designed to use Ampex 456. |
If you know that your 38 was setup for the 456 equivalent, you won't need to recal, but if its been awhile it wouldn't hurt as things drift and yours clearly had a rough trip
![]() . Regardless you should check the bias. SM911 and 456 are bias compatible but there are always sliught variations, even between different batches of the same make and model of tape. Plus, again, it had a rough trip. |
Also, a place local here wants $170 to calibrate/align. I don't know if that's reasonable considering I have not been in the analog arena for about 15 years. |
VP ![]() VP |
| Finally, back into analog | Seeker of Rock | Analog Only | 24 | 01-23-2007 14:59 |
| i am sooooo going back to analog........ | turtlishous | Digital Recording & Computers | 26 | 11-10-2006 03:30 |
| Back to analog...all the way! | SkyLounger | Analog Only | 12 | 09-04-2006 14:05 |
| finally back to doing some analog | pbergo | Analog Only | 1 | 07-28-2004 19:45 |
| PC to Analog 8-track and back to PC - HOW? | mborum | Digital Recording & Computers | 2 | 12-12-2000 12:44 |
