plugins
Hello, I switched over from protools after Digidesign bricked my hardware.
I've been using Reaper to work on mixes a little when I'm away from home. I'm on my first day recording with it, and so far it's great. Very intuitive. I had a problem using antares autotune vst (go ahead, make fun) with it. What's the typical routine for installing plugs to use with reaper? Are there certain kinds that work better than others as far as compatibility goes? Is there another autotune I should use instead ("Yeah, NO AUTOTUNE! HAW!") Thanks for any help. |
Aren't TDM plugins proprietary to Pro Tools?
http://www.myspace.com/onebadassdude |
Yeah, TDM (and RTAS) are proprietary plugin formats for DigiDesign Pro Tools. Antares does, however, make a VST version of AutoTune which most likely came with it when you purchased it.
As for alternatives, GSnap is a great free pitch-corrector. REAPER also comes with the ReaTune pitch corrector and ReaPitch pitch adjuster. (I often use ReaPitch with automation to manually correct vocals. GSnap is really a great plugin too.) |
I've never used anything but PT, so I'm learning these facts only now. Thanks!
Not a problem
![]() If you have anymore questions about the plugins I mentioned, just ask. I use them on an almost-daily basis. |
| I need plugins.... | jamesduysen | Digital Recording & Computers | 8 | 06-30-2006 20:07 |
| Plugins | DonaldChang | Mixing / Mastering | 3 | 07-15-2005 05:59 |
| Where can I get a VST wrapper to make VST plugins work like DX plugins? | coplinger | Digital Recording & Computers | 2 | 09-25-2003 05:26 |
| which plugins do I Have? | MartyMcFly | Digital Recording & Computers | 0 | 06-15-2002 12:28 |
| How many plugins can you get?! | The Garage | Digital Recording & Computers | 6 | 01-25-2002 15:42 |
