Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 07-27-2009
SRREYNOLDS2003 SRREYNOLDS2003 is offline
Newbie
SRREYNOLDS2003 is on a distinguished road
Microphone volume with reaper
I am new to reaper and recording and I have a real simple recording set up at my house. I use Windows Vista, a Behringer UCA202 USB interface and a Shure SM58 to record my vocals and acoustic guitar I am just staring out.
So My question is how do i adjust the gain on the microphone or track when I am ready to record.
I recorded a vocal track and it seems really low in Gain.
So is there somewhere on reaper where you adjust the Track input/recording Gain
Please help a Newbie out.
Steven
Old 07-28-2009
gecko zzed's Avatar
gecko zzed gecko zzed is offline
audio illusion
gecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond repute
Steven
In this case, Reaper will not provide the answer.
The UCA202 needs a line level input to work properly, for example, the level that you would be likely to get out of a mixer or a pre-amp.
How are you connecting your mike to the interface? This is where your problem is most likely to stem from.
I have a theory about that
Old 07-28-2009
FunkDaddy's Avatar
FunkDaddy FunkDaddy is offline
Senior Member
FunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond repute
One of your problems might be using a dynamic microphone, might find it hard to get a decent level without a preamp with lots of gain.
Old 07-28-2009
d.bop d.bop is offline
Senior Member
d.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond repute
I "third" getting a preamp. Mic level and line level signals aren't the same.
ART makes a cheap and decent tube preamp (ART Tube MP Studio) I used to have two of these and they worked great not only as mic preamps, but also as DI boxes.
$29.99, not bad
Old 07-30-2009
Newbie
thanks for the info...I will definetly check out the preamp
Old 4 Days Ago
jacobharris jacobharris is offline
Registered User
jacobharris is on a distinguished road
A quick solution is a xlr to 1/4 in cable and just recording through an amp.
its what i do.
Old 4 Days Ago
Senior Member
its what i do.
Yeah... it's not really a good idea to mismatch the impedance of a source and a load.
Mic, Instrument, and Line level signals are all different from each other. It's not just about volume. Not to mention the noise coming from the amplifier (among other things) will also degrade your mic signal.
EZDrummer - Cymbal volume low/can't change volume ido1957 Drums and Percussion 0 06-17-2009 20:14
Microphone records at low volume. audiomeanie Microphones 4 04-06-2009 06:11
When my microphone's volume is turned up to a decent level I get distortion Jim Digby Pro Tools Forum 9 09-08-2008 21:31
AKG C 414 B-XL II Condenser Microphone vs Blue Woodpecker Active Ribbon Microphone airlyons Microphones 1 09-28-2007 16:51
I usually play with my guitar volume knob all the way up, and control the volume with monty Guitars and Basses 24 07-13-2004 20:14
