Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 07-26-2009
Ernesto Marani Ernesto Marani is offline
Registered User
Ernesto Marani is on a distinguished road
How can I apply an effect to a selection in Multitrack view? Pls help!
Hi everybody,
I want to apply an effect to a selection when I am in multitrack view (I use Audition 1.5). For example, to silence the selection (at the same place and in every track). How do I do that? Pls help!
Thanks
Old 07-26-2009
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
if Im understanding you correctly, you need to use the envelope tools...there are envelopes for volume, panning, and effects....Im not on my studio PC right now, so I cant tell you exactly where you choose these, but there are buttons at the top of the screen in multitrack mode that will take care of this for you...
Old 07-26-2009
oretez oretez is offline
Hwy 50
oretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond repute
There is no dynamic automation in AA 1.5 (one of the items on the perennial wish list, it did, I think show up in AA 2 (which I never used) and AA 3)
One can manually set amplitude envelops but you can not save, copy & paste, envelops so if you have more then a couple of files this gets tedious.
Prior to AA 3 Audition was primarily an editor, with some multitrack capability rather then a full fledged tracking/mixing environment
I know we struggled with this stuff for years and there might have been a work around . . . I know output from a bus was only to hardware (not to another track), there was no way to create a 'master track' whose volume could be controlled via envelops (idea being route all tracks whose volume you wanted to drop at the same moment to a bus (or master track) then manually adjust that tracks envelop (there were individuals who explored using virtual audio cable (as bus output) but can't remember how successful they were)
One could of course mix all the tracks having the volume drop at the same point and adjust volume on the mix (in edit mode) or insert that back into the multitrack and adjust with envelope
Was trying to remember if there was a dynamic Fx that might get you in the ball park . . . Had to be dynamic to have an Fx envelope . . . But even there the FX or Wet/dry mix envelop was editable only on individual tracks
With a large number of files (if the volume reduction occurs at the same time (from start) in each file) you can create a script and batch process the rest of the files (this is destructive edit and you want to work from copies of the files)
fx in multitrack view jbonil1 Cool Edit Pro / Adobe Audition Forum 2 05-08-2006 09:44
Sonar 4 - Apply effect to a portion of a track? mncheetah Cakewalk / Sonar Forum 3 02-10-2005 12:28
Moving waveforms in multitrack view MC Groves Cool Edit Pro / Adobe Audition Forum 2 04-26-2004 13:35
CubaseSX vs Logic (pls view) rockem Digital Recording & Computers 8 08-13-2003 06:29
