Old 07-25-2009
Goldenvoice388's Avatar
Goldenvoice388 Goldenvoice388 is offline
Junior Member
Goldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond reputeGoldenvoice388 has a reputation beyond repute
Otari MX5050BQII transport control issue...
I cleaned up the budget Otari MX5050BQII I drug home, and set about to run a basic series of test. Didn't take me long to encounter a problem.
Play works - stop works - back to play - record seems to work, but...
If I push FF, it just stays running at high speed, and the only way I can figure out to stop it, is to turn the unit off.
Same thing: hit RW, and it will rewind as long as I hold that button down, but if I let it up, it drops into FF - and sticks...
My brain tells me there might be some sort of sticking relay in there somewhere?
Any ideas?? (maybe I'm doing something simple like threading the tape wrong, but it seems pretty straight forward)
Joe
Newbie here - but not there...
Old 07-25-2009
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
I have to applaud your creative use of the word 'drug' there :P
Anyway, I haven't found full schematics yet, but from the parts manifest I could find, the BQII seems to have a tape control IC and flipflops, so I'm not sure a relay fault is going to have that kind of symptoms.
Assuming it's not something simple (does it still do this if there's no tape threaded and you defeat the switch?)
It sounds like either the IC itself has gone nuts, (IC8 on the control board apparently, don't know what it is or how obtainable) or the inputs to the IC are wrong and it is getting confused.
Now that I think about it, it sounds very much like what the TSR-8 does if the tach roller malfunctions. If you look on page 15 of this:
http://www.otari.com/support/pdf/mx5050bqii.pdf
...towards the bottom, marked #22 there is a toothed sprocket, which appears to be a direction/tach wheel. There's a photosensor next to it.
I would almost bet money that your problem is a problem with that tach wheel or the photosensors monitoring it.
TM-D1000 as transport control for Sonar C. Anthony TASCAM User Forum 3 3 Weeks Ago 08:44
Pinch roller for Otari MX5050BQII ? Goldenvoice388 Analog Only 4 07-23-2009 21:07
MMC to control transport controls? LemonTree MIDI Mania 0 02-28-2008 01:32
Transport mapping/control in Reason 3.0 stuck_on_music MIDI Mania 1 08-19-2007 10:32
DAW transport control foot switch? paresh Other Equipment and Reviews 4 05-16-2007 13:13
