Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 07-17-2009
Somelsewhere Somelsewhere is offline
Newbie
Somelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond reputeSomelsewhere has a reputation beyond repute
Mixing Down in Reaper
Okay, so I guess my first question is:
are there any drawbacks to having alot of tracks on one song, like does it it harm the computer's processing power at all, so far I have 20 tracks on one. Really, I just need some vet to be like "I have like 600 tracks on one song, don't sweat it."
and,
once I have the volumes and panning pretty much set for a group of tracks, how do I cram them all into one track in the Reaper software?
thanks in advance.
Old 07-17-2009
buckkillr8's Avatar
buckkillr8 buckkillr8 is offline
David Gilmour's clone
buckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond repute
sure it does. The more tracks the more work on the CPU. Add some plugins to those tracks and it'll really be sweating.
My Gear
Old 07-17-2009
oretez oretez is offline
Hwy 50
oretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond repute
thanks in advance.
render in file menu
Old 07-18-2009
VomitHatSteve's Avatar
VomitHatSteve VomitHatSteve is offline
1K Silver Member
VomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond reputeVomitHatSteve has a reputation beyond repute
That's true. Though individual tracks with no effects don't take a lot of CPU. I've had dozens of raw tracks playing at once with no observable performance hit, but once I add effects to about 6 of them, my system really slows down.
Old 07-20-2009
AndrewClaycomb AndrewClaycomb is offline
Senior Member
AndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond reputeAndrewClaycomb has a reputation beyond repute
Just finished an album for a hard rock band that had 48-78 tracks per song. I did that on my aging laptop. I did run out of processing power if I tried to record with effects turned on during playback. It was easy enough to just turn off all effects while tracking.
Now I have a dedicated DAW and don't run out of steam anymore. I also record to external FW drives, so the main hard drive doesn't have to compete for resources.
Keep up with defragmenting your drives and you shouldn't have an issue with playback unless you go crazy with samples and/or effects. If that's the case you should just render everything.
Old 07-24-2009
DarkFriend's Avatar
DarkFriend DarkFriend is offline
Senior Member
DarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond repute
Yeah, Reaper seems to be really good with tracks. I usually have 30-40 per song, most with effects running. The thing that seems to bog down Reaper (or any workstation) are the effects. Some are well-coded and efficient (Waves and the Reaper native effects come to mind) and some are bloated and bog down a system (some guitar amp simulators come to mind).
You can "freeze" tracks which is creating WAV files with the effects "printed" and that will save resources. Also, I've found that higher sample rates than 44100 can cause performance issues.
Reaper and what I need? All4Love Don't Fear The Reaper 3 06-05-2009 11:33
LE 4 or Reaper?? UnityRecordings Cubase User Forum 2 10-05-2008 21:57
Anyone know reaper well? daav Digital Recording & Computers 9 07-19-2007 12:58
Reaper? 88fingers Digital Recording & Computers 3 03-28-2007 09:45
REAPER is 1.0! pipelineaudio Digital Recording & Computers 28 09-02-2006 00:48
