Old 07-11-2009
frydek frydek is offline
Registered User
frydek is on a distinguished road
Adjusting meters
Hi,
I'm new here, great forum!
I'm new to tape machine, I don't actually own one but I'm considering it.
I was offered one but the seller mentioned the meters may need adjustment.
Is that a difficult thing to do? I mean is just something like using a screw driver for adjustment so it shows 0 VU with a voltage of 1.228V?
Thanks
Old 07-11-2009
Victory Pete's Avatar
Victory Pete Victory Pete is offline
Thinking outside the box
Victory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond repute
Thumbs up
Hi,
Welcome! It can be as simple as that, That is the level for +4. If the level is -10 it would be 316 mv. Are the meters VU or LED?
Victory Pete
Old 07-11-2009
Registered User
Thanks.
The meters are VU. Would it be different if they were LED?
Old 07-11-2009
Well it is easier to set the VU meters because you can see your adjustments in small increments. The LED segments have a + or - window of 1/2 db where they will still be lit. On my Tascams I set the LED meters so at 300 mv the 0 db LED just turns on, That way they are all set the same and the 316 mv will be in the middle of the LED's range. What machine are you considering?
VP
adjusting bpm in reason for PT? poopchute Keyboards and Sound Modules 2 04-10-2009 14:07
adjusting bridge question444 Guitars and Basses 9 01-31-2008 11:22
adjusting the nut mikey@thecave Guitars and Basses 10 12-08-2007 10:46
adjusting buffer dolecek1 Cubase User Forum 1 08-31-2005 13:37
Motu 896 meters vs. Cubase meters? affleckp Cubase User Forum 1 06-09-2005 12:18
