Old 07-08-2009
adrianhouse adrianhouse is offline
Junior Member
adrianhouse is on a distinguished road
Tascam 414mkII problem
Hi y'all,
Got a 414 from advice on the forum, and so far very happy with the results from it. However it has recently developed a problem and I'd really appreciate any advice on this - I'll do my best to explain. The problem is that when I playback my recording in "mixdown" mode, i.e. with the Monitor L-R button on and the other monitor buttons off (and all the switches on "tape"), I can no longer hear it in the headphones. It comes through perfectly if I connect the lineout rca to an amplifier and go through speakers, but nothing through the headphones, suddenly. I can hear it if I turn the monitor level up, but then can't adjust the balance between tracks. It almost seems like it's only patching the monitor signal to the headphones, and not the "line out" signal anymore. The result through the headphones is the same as when the rca is plugged into the "mon out" and then into amp and speakers. Any ideas? It's annoying not to be able to listen to the "final product" through the headphones.
Thanks for your help,
Adrian
ps. Here are some recordings I've done previously:
www.myspace.com/theconnexions
Problem with my Tascam 414MKii eternaltwilight TASCAM User Forum 1 12-16-2005 17:29
Problem with my Tascam 414MKii eternaltwilight TASCAM User Forum 0 12-16-2005 15:05
Tascam 414mkII boydeadly TASCAM User Forum 8 07-22-2005 08:06
tascam 414mkII problem thirty2seconds Other Equipment and Reviews 8 02-07-2005 02:25
Tascam 414mkII mikemoritz Free Ads for Music / Recording Equipment 0 10-12-2001 15:38
