Old 07-06-2009
xllund xllund is offline
Registered User
xllund is on a distinguished road
Audible Humming Noise! Not Sure Why
Hello All,
I am new to this site, and I hope that I have posted this problem on the correct forum.
SETUP> Yamaha YPG-635 keyboard, using headphone jack as output, it is then split to L & R plugs entering a Boss RT-20 pedal. Stereo inputs used, and stereo outputs used. From the pedal, L & R ouptut leads feed into a Lexicon Alpha mixer. Stereo in, and stereo out to studio monitors.
PROBLEM> When connected as described above, I am getting a low volume humming noise during recording (Cubase LE-4 software.) It reminds me of amplifier noise, such that you would experience when you unplug a guitar with the amp volume raised.
When I bypass the mixer and go straight into the studio monitors from the RT-20, no problem at all. Do I need to get some sort of filter? I am stumped, and any help would be greatly appreciated. Thank you to all in advance.
Xllund
Old 07-06-2009
mjbphotos's Avatar
mjbphotos mjbphotos is offline
Dedicated Member
mjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond reputemjbphotos has a reputation beyond repute
Sounds like the mixer is amplifying the hum brought into the chain earlier - the keyboard's headphone output is the only option? No line out available?
Old 07-06-2009
gecko zzed's Avatar
gecko zzed gecko zzed is offline
audio illusion
gecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond repute
My inclination is to check the pedal. If that's running off a wallwart, you might like to try switching to batteries. Better still, don't use it.
I have a theory about that
Humming Noise RD423 Pro Tools Forum 2 08-30-2008 20:11
Wierd humming noise Bulls Hit Guitars and Basses 10 04-11-2006 05:40
Humming noise when i record on my p.c. sidestream Recording Techniques 7 03-05-2006 20:21
Mini mix 16:2 making a humming noise when i try to record.... sidestream The Rack 4 03-05-2006 20:01
Humming noise with my recording. Why? muhairwejas Mixing / Mastering 8 07-27-2002 17:01
