Old 07-03-2009
EleosFever EleosFever is offline
Junior Member
EleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond reputeEleosFever has a reputation beyond repute
Microphone picks guitar picking
Hello, When I'm playing guitar and i singing in the same time (microphone is one the stand) it picks my picking from the guitar.. It's so annoying..
Ok maybe it's a silly question but what can i do to reduce it?
Old 07-03-2009
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Not sure if you want less guitar (move to the voice and away from the guitar) or a different or less pick noise -light picks give less inst. vs pick volume, heavy more inst. volume and a more solid tone.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 07-03-2009
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
He's hit it right on the head. Thin picks are really bad about this. The heavier the pick, the louder the guitar sound will be vs. the pick noise.
The only other thing that this could be is that you have a really quiet guitar and sing really quiet. If that's the problem, sing louder and get a guitar that projects.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 07-03-2009
Tim Gillett Tim Gillett is offline
Musician/technician
Tim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond repute
It's also stating the obvious but stay as close as you can to the vocal mic so your voice is louder re the guitar. Reduce bass response to conter proximity effect. Add a foam windshield to reduce the inevitable popping at close micing.
Another option is a headworn mic which allows you to get consistently close micing while not restricted to a stand mic's limitations.
Vocal and guitar is a notoriously difficult combination to achieve separation, both ways. Hard to set up both mics so they are rejecting the other source effectively. Close micing on both helps.
Old 07-03-2009
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
Heres a novel Idea...record them at seperate times...this will solve this problem 100% of the time.
Ive worked with a few stubborn Coffieshop folk singers who cannot seem to be able to do one without the other...and sometimes you do get some bleed in the vocal channel...and vice-versa...use a parametric to get some separation in that case.
wayne
Old 07-03-2009
Farview's Avatar
If you need separation, use figure-8 mics and point the null of each mic at the thing you don't want it to pick up.
Jay Walsh
Newby MIDI Controller question Shoulderpain Newbies 10 02-13-2008 22:47
newby question! cemyender Cubase User Forum 2 02-02-2007 16:03
Oldie Newby Stupid Compressor question tkrinor The Rack 17 05-04-2006 14:25
Newby no frills type question... bjh65 Newbies 6 07-03-2003 06:27
will this work ? (newby question) Peter Cubase User Forum 1 03-04-2002 07:23
