this type of back vocals?
hi!
how can i make this type back vocals ,this is a rick ross video,also lil wayne doing this thing a long ago .check the video ; http://www.worldstarhiphop.com/video...n8XUj9H5umw9Rb tnx! |
You mean the delay? It sounds like a simple delay. i didn't hear a single backing vocal at all.
That's a delay effect that probably uses a tap button. A delay is an effect that simply captures what is spoken and then repeats it back a few milliseconds later. The number of milliseconds can be adjusted to up to maybe a full second or more. That is called "delay time."
The tap button makes it easy to set the delay time of the echo so it appears equal to the tempo of the song. You simply tap the button a few times (at any even tempo) and the delay time is automatically adjusted to that timing. Cool, eh? |
also the tap button where and how will i do that thing? tnx again! |
That is way too technical of a description for me; I have no idea what that means.
To do what these other folks are describing without having a tap switch feature to do it manually, set the delay to match the tempo of the song. Start with the formula 60,000/BPM = the number of milliseconds delay for a ¼ note. If you need a delay for an 1/8th note, divide that number by 2. For a 1/2 note, multiply that number by 2, etc. G. |
Its not a crazy delay, so I would start with minimal settings and work up as needed. |
| I'm looking for a certain type of effect with vocals... | jndietz | Mixing / Mastering | 16 | 04-30-2008 23:13 |
| Vocal Mic for Dylan/Strummer type vocals | cmyhre | Microphones | 3 | 12-29-2005 17:27 |
| Back up vocals | Vin-Su | DJ & Hip Hop Production | 5 | 04-29-2004 09:26 |
| back up vocals | paresh | Mixing / Mastering | 5 | 08-26-2003 07:15 |
| Vocals, Reverb,Chours..Which type and how much? | cagedconfession | Mixing / Mastering | 9 | 10-06-2002 22:58 |
