Old 06-23-2009
Boongoon Boongoon is offline
Newbie
Boongoon is on a distinguished road
Mixing a live band at a bar
Hello,
I am new to all of this. I am the drummer in a band and have taken on the responsibility of recording our shows. I have an Alesis multimix16 USB2.0 and i am using Acoustica Mixcraft on a Dell Laptop.
The other night i had everything set up and we had 8 tracks. The problem was we were afraid that our PA could not handle all the input without clipping. We had to reduce all the levels except the vocals.
My question is this; is there a way to record all the channels with levels set accordingly through the mixer into the software but only have select channels actually come out of the PA?
Thanks,
Evan
Old 06-23-2009
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is online now
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
My condolences.
It's next to impossible in most circumstances to create a single mix pattern that will work well both for the PA and for recording.
If you're not using the mixer's Aux send bus to feed stage monitors, you can use that to feed the PA, allowing you to use the aux send levels to mix the PA mix.
Otherwise I'd run the direct outs from your input channels either to a submixer or to a multitrack interface for your laptop.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 06-23-2009
oretez oretez is offline
Hwy 50
oretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond reputeoretez has a reputation beyond repute
on the mic channels set gain with trim pot and fader all the way down
signal routed to computer not to main mix
alternatively you could assign alt 3/4 as you FOH mix continue to use faders on all the channels merely not route the channel you don't want in FOH to the alt 3/4 bus
Old 07-10-2009
Newbie
I had the faders and gain all the way down and nothing routed to the computer from those channels.
Old 07-10-2009
Newbie
As i said i am new to all of this, what does FOH mean?
Old 07-10-2009
FOH= "Front Of House". It simply refers to the live mixing for the PA - as opposed to the recording mix. The needs of each are quite different.
G.
Glen J. Stephan,
Recording of a live band in a bar EddieRay MP3 Mixing Clinic 23 08-11-2006 01:22
Advice for newbie mixing band at bar sindawg Newbies 18 03-01-2006 20:11
Recording a band Live at the local bar lurgan liar Newbies 7 07-18-2005 09:48
Any tips for recording live in a bar/club? EddieRay Recording Techniques 15 05-13-2005 17:35
Don't know where else to ask...live band mixing question. JSCRyan Mixing / Mastering 5 04-21-2005 07:55
