Pot replacement on Alesis
I have an old Midiverb III I would like to replace the pots on. I know that normally it probably isn't worth doing on the old thing but for what I have into it (zero $), why not. Would anyone know the values on these pots? And if they are audio or linear taper?
Thanks all. |
OK...I have taken the top off and found stickers on the back of each of the three pots. Input, Mix, & Output. Both the Input and Output are labeled "A10K" which I assume is a audio taper 10k ohm pot. The Mix pot is a bit different. It is labeled "B1K" I would take this as a 1k ohm pot but unsure from there. Any ideas???????
I believe they are linear taper. You should be able to find them through Digikey or Mouser. Try here....
http://www.mouser.com/catalog/637/675.pdf Possibly something like Figure B???? I don't own own a Midiverb, so I'm unsure of..ahem...shaft length and mounting structure. ![]() |
Who'd have ever thought that someone calling themselves M10K would know about pots...
It's not just the signal chain... It's the hands that touch it |
Intrumentalparts.com offers them but they say it's a "special order" item. Sent an email straight to Alesis to see if they can help.
Neither Digi-key or Mouser had them that I could find. But, I did find them elsewhere.
| Is a dirty pot a noisy pot when NOT being turned? | slowmotion | DIY, Mods, and Homebrew | 6 | 11-30-2008 16:46 |
| ES335 Pot Replacement | apl | Guitars and Basses | 15 | 09-01-2008 10:13 |
| 300kohm Pot vs. 500kohm pot | oDD | Guitars and Basses | 3 | 02-17-2007 22:15 |
| Replacement pot for my Marshall Valvestate 8080 | qbert1 | Guitars and Basses | 1 | 11-22-2005 00:24 |
| Wah pot replacement | Krystof01 | Guitars and Basses | 5 | 04-14-2002 01:00 |
