Old 06-09-2009
BenignVanilla BenignVanilla is offline
Senior Member
BenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond repute
Stereo/Mono Button
How do YOU use the stereo/mono buttons? I tend to leave everything set to stereo on all tracks. I am wondering if I am missing some greater purpose here.
Old 06-09-2009
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
What program are you using?
If you are using stereo tracks, you use the stereo button
If you are using mono tracks, you set it to mono.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 06-10-2009
mattr's Avatar
mattr mattr is offline
Resident stroppy teenager
mattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond repute
Not always.
In Sonar (like most DAWs) you can have both mono and stereo audio on the tracks, however next to the pan slider on each track there is also a mono/stereo button. This affects how the track is sent to the next step in its routing (bus, master bus, etc).
Obviously if you have stereo audio you'll want to keep it in stereo, but also if you are using stereo plugins on mono tracks such as reverb you'll also want it set to stereo as otherwise the reverb will be collapsed to mono.
So even if you have mono audio, doesn't mean you have to have the tracks set to mono. It does no harm having them set to stereo, so I would just carry on doing what you're doing. I've been caught out before wondering why the stereo reverb on a track was coming out in mono, and it took me a while to realise it was those damn buttons
Old 06-10-2009
Monkey Allen's Avatar
Monkey Allen Monkey Allen is offline
creeping moses
Monkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond repute
If you are talking about the stereo interleave button and how it should be set in consideration to certain plugins then this is how I see it:
If 3 people walked into a shop at half past 1 and stayed there for a combined total of 20 minutes, with the first person leaving the shop after 2 minutes, while a further 6 people entered the shop 17 minutes after the first person from the first group left, of whom only 4 people stayed for a duration longer than the first person from the first group of people, how many people would the shop......
I can't get my feeble head around it. I've read one conflicting answer after another on the net
the park job in 7a
Old 06-10-2009
mattr's Avatar
The best thing is just to play
Even though I usually use reverb with sends and buses, the best way to demonstrate is using a reverb plugin.
Load up a mono vocal track and leave it panned centre. Add a stereo reverb plugin as an insert and get a fairly large, wide reverb going.
Toggle the switch and make up your own mind about what it does...
Old 06-10-2009
creeping moses
I agree, that's the best way
the park job in 7a
Old 06-10-2009
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Originally Posted by mattr View Post
Not always.
Yep. Basically leave it 'stereo, unless you're forcing to mono. Mono tracks stay mono +/- stereo plugs etc. The track paths, busses etc are all stereo' (dual path?) by default regardless of a track file being mono.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Sample - mda Stereo (turn mono track into wide stereo image) danny.guitar Digital Recording & Computers 10 12-01-2007 03:59
Carver A-500x Rear Button From Stereo To Mono NBWX Other Equipment and Reviews 1 09-21-2007 07:57
recording mono signal via spdif(stereo), how to convert this to mono? earworm Cubase User Forum 3 05-29-2005 13:35
Does the Cubase SX mixer have a mono button? PersonalJesus Cubase User Forum 21 04-20-2004 02:44
Difference between mono, dual mono and stereo... tubedude Microphones 0 06-26-2001 03:32
