Another Brick in the wall...limiter
Reading the forums, I see many critical comments on brick wall limiting. I understand where they are coming from, and when I listen to modern music I have the same sort of complaints about the recordings now, but here's my conundrum.
Often, I will come up with a mix on one of my tunes that I like...I'll dump it out of my DAW, and then listen in iTunes....and I get a quiet drab tune. So I end up going back to my mix, and using a brick wall to bring my entire mix up just shy of 0db. So I am thinking to myself tonight...is the problem the brick wall'ing or the way it is done and being used? Is there a proper way to brick wall your mix without hammering your mix? I am thinking brick wall limiters don't kill people...engineers do. |
Limiters kill transients...end of story
So help a newb out...I complete my mix, and the output is low...do I go back and kick the level up on everything?
There's different things you can do. Often times I just normalize the stereo mix and be done, but that's because I'm a good arranger and mixer. If there's random peaks that just tower over everything else, find out what causes those, go back to the mix, and use volume automation to notch them lower.
You can also do some light compression, there's two ways of doing this....something like 1.5:1 or even 2:1 set to a low threshold, so everything is mixed, or something a bit heavier like 3:1 set to a high treshold that captures any other loud transient and 'tames' them. There is this brand new plug-in that I discovered called TesslaPro that I'm planning on using as the only plug-in on my stereo buss. Its a transient smoother, and sounds REALLY nice. Really, that's all you need to get some good punchy stereo tracks. |
Somewhere in there is your middle ground, A/B at equal loudness is our cross check. ![]()
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
make sense? |
The first thing it requires is a mix that can handle being thrown against a wall without breaking. Hell, most of the pro stuff I hear that is flattened these days sounds broken, because the paymasters just don't give a shit about how things actually sound any more. But usually they have mixes that are finished and sound great to begin with; you have to have that "lead" in quality, because the crushing is only going to make it sound worse. Second is to inch your way towards that brick wall step by step, don't just run into it at full speed from 30 feet away. This often means compressing in steps, and fine-tuning the EQ at each step (if/when necessary) to hold things together as you go. Finally when you do limit, after all that earlier stuff it'll be easier to try to keep the total amount of gain reduction to 2-3dB or so, which can lessen the blow (so to speak) of hitting that wall. There are other tricks, such as running the final mix back through your converters again at slight over-gain and letting then clip off a couple of db, and so forth. You just gotta decide whether you want to go through all that effort just to make your stuff sound worse than it does now. G. |
You may be either setting your threshold too low or setting your output gain too high. You should be tweaking these to adjust the end result. You don't want your overall waveform to look flat across the top. You should be able to find a happy medium in there somewhere.
| A brick wall. PLEASE HELP | Mull | Recording Techniques | 32 | 02-24-2009 02:39 |
| I've hit a brick wall... | RatedZ | Guitars and Basses | 37 | 01-08-2009 14:20 |
| I Think I Hit A Brick Wall.......Ouch! | MusicallyMrM | MP3 Mixing Clinic | 7 | 11-21-2003 08:40 |
| Brick Wall Treatment | the dude | Studio Building & Display | 7 | 10-09-2003 14:16 |
| Brick Wall Limiter Recommendation | fibes | The Rack | 2 | 04-13-2003 23:21 |
