How to Pass from ProTools to Sonar
Greetings, everyone, my first post! I have been a Cakewalk user since Cakewalk 3, now in Sonar 7...I have an urgent project to complete and have decided to go to a semi-pro studio and 'capture' everything, then (hopefully) pass to Sonar somehow & bring to my home studio to finalize, mix etc. The obvious problem is the incompatibility problem, so I'm researching THE BEST WAY TO TRANSFER FROM PROTOOLS/MAC OS TO SONAR/WINDOWS OS - how would you do it, if you were me? To maintain the best sound quality. Have been told by once source that .OMF files are the way, via DigiTranslator - anyone had experience with this? TIA!
OMF (Open Media Framework) was designed specifically to pass projects from one sequencer to another.
http://en.wikipedia.org/wiki/OMFI Read the help files and manuals..... Otherwise, you'd have to render out each track from 0:00 to end-of-song as .wav files Starting everything at 0:00 makes everything line up properly. |
You may want to double check that the Pro Tools session is creating WAV files. It should be, that's been standard on Mac systems for a few years now. To physically transfer the files from one computer to another, use a firewire or USB drive, or burn a DVD.
Eric Practice Your Mixing Skills! Mix Our Tracks in Your DAW! www.Raw-Tracks.com Online Mixing Forum |
| Protools and sonar | jmorris | Cakewalk / Sonar Forum | 2 | 06-03-2008 17:38 |
| Using a high pass or low pass filter | rgraves | Cubase User Forum | 7 | 11-22-2006 07:57 |
| High pass filter in Sonar 3.0? | Mountainmirrors | Cakewalk / Sonar Forum | 1 | 10-25-2003 17:53 |
| SONAR as pass-through processor | JApthorp | Cakewalk / Sonar Forum | 1 | 07-24-2001 09:06 |
| how can i draw an envelope for low pass in sonar? | r0cker | Cakewalk / Sonar Forum | 0 | 07-06-2001 10:45 |
