Putting compression on the finished mix
Does anyone put compression on the finished mix? Is this typically done.
I wanted a way to make the mix louder while preventing the high points from clipping. Here's a track I used compression on: http://soundclick.com/share?songid=7540892 Does it sound alright? Thanks! ![]() |
I can't listen to your track right now, but I can tell you the 'louder is better' attitude about compression and limiting on the whole mix is going to kill the dynamics of your music and leave you with a lot of distortion. Using it sparingly will bring up your percieved volume, but that's not always a good thing either. Believe it or not, at louder volumes, the ear fatigue will actually make the listener turn it off rather than listen to the whole thing. You would be better off just making a good song, tracking it correctly, and mixing it without the artificial loudness.
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid. |
Yes Jon P, even the most dynamic mixes will have at least some compression added to the final mix. I normally always mix to a compressor inserted across the master. As Rokket says though, a compressor across the final mix isn't really about trying to get the mix loud, although it helps...it's more about evening the track out. Making the soft bits louder and the loud bits softer. One of the main uses for this I find is when playing my music in my car. Without compression, I have to turn up and then turn it down again as I drive which is never a good thing.
Anyway...enough of that as I'm sure people of fed up of this debate. I think you have the compression about right on your song Jon P though I'd consider dropping the db down abit on the bass...it sounds a little artificial. You have a great voice though my friend...really enjoyed the song(especially compared to the Whitney version )Mart. |
If you have to ask, you've got the wrong hobby.
![]() A far better question is whether it sounds OK to you. G. |
Whether that constitutes 'too much' for the genre I'll stay out of.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
If you're not sending it off to be mastered, then yes, in a pinch compression, limiting, and normalization will get your track up to the level of a mastered CD. There's a lot more to mastering than this, but (and mastering guys, please don't hurt me! ) this will at least get the volume up closer to a mastered product.
"They can kill you, but the legalities of eating you are a little dicier." - David Foster Wallace |
I was thinking about the dynamics too, that's why I was a little unsure if compression was something typically used for this sort of thingQuote:
I lowered the bass in the current version. I hope it's a little better now.Quote:
![]() Quote:
Great to hear that you think the dynamics have been retained and glad you like the song. I didn't notice the vocals getting pulled down, so it's not intentional, haha. Which part is it?Quote:
Compression can actually modulate the vocal? That's cool, how does it work? Does compression create a certain sound as I've heard people saying how adding too much makes it evident that there's compression (I'm such a newbie, haha).Thanks again! |
Lately...I've been experimenting with a MBC on my final bus, and using it almost like an EQ to make my final mix...for lack of a better term...pop.
Just as an aside...for all of my mixes...I add a stereo bus in my DAW, and have all tracks/buses output there...I then output this final bus to the master. So any final tweaking, as in the case of the use of an MBC, is done here. Quote:
The other way to get there is on mixed material where you have a vocal for example going along not triggering much reduction and then one or more instruments are rather ‘hot in the mix come along and cause more reduction. Everything gets pulled down together, but now the vocal is reduced from its previous ‘normal level. What I am hearing seems to conincide with the whole or half note down beats on the backing tracks. -quarter second duration 'ducks, quite a bit slower than vibrato. ![]()
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology Last edited by mixsit; 06-09-2009 at 22:07.. |
#12
#13
#14
Since the audio is split up into separate frequency bands, is this how mastered recordings get that three-dimensional sound? |
#15
The beauty of an MBC is that you can compress with a more focused approach, so if your drummer is pounding the kick at one point, but the vocals are not screaming, you can compress the frequency range of the kick and not affect the vocals. Over simplified description, but I think it gets the point across.
| 1st Finished Mix | nothingtodiefor | MP3 Mixing Clinic | 2 | 02-25-2009 09:17 |
| Need opinions on nearly finished mix | NL5 | MP3 Mixing Clinic | 7 | 08-26-2008 08:53 |
| Just finished mix.. | Bassmusic808 | MP3 Mixing Clinic | 0 | 03-07-2008 18:27 |
| Just finished putting the Kurzweil KSP-8 through its paces..... | Blue Bear Sound | The Rack | 14 | 11-02-2004 11:11 |
| Putting reverb in the headphone mix while recording dry? | bigwillz24 | Newbies | 2 | 08-02-2004 15:40 |
