Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 06-01-2009
McLovin McLovin is offline
Registered User
McLovin is on a distinguished road
DP-02 CF Import blues.
I'm a fairly new user for the DP-02 CF. I'm having a nightmare importing tracks successfully. I'll go through my check list and if anyone can spot what I'm doing wrong please post, otherwise it'll be tech support shame for me.
1 New card 2gig, format and create a FAT partition.
2 Song ready to go.
3 Open USB.
4 Drag and drop .wav file into the WAVE directory.
5 Close USB.
6 Go to Menu>wave>import track.
at this stage it says "import file not found" or something similar.
7 Open USB, check file is still in WAVE. It is. Repeat 5 and 6 to the same result.
the last time I did this my laptop posted a warning bubble that the "delayed write had failed.harddisk file 11 had failed to write and the data was lost"
If anyone can tell me if it is a desk/laptop/cable issue I would be v grateful
Old 06-02-2009
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow Yeah.
The only tip I can offer is the DP02 will only recognize a 16-bit/44.1kHz/MONO wav file,... not your typical stereo wav file you'd normally get on your 'puter for listening or directly off a commercial CD.
I've never rendered a mono Wav file, but I've heard there are programs that will convert stereo wav's to mono. It may just be a setting in your DAW software to do this.
Good luck.
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
Old 06-02-2009
jjones1700's Avatar
jjones1700 jjones1700 is offline
Learning, always learning
jjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond repute
Originally Posted by McLovin View Post
3 Open USB.
5 Close USB.
At first that warning made me think that maybe you weren't giving the file enough time to copy before closing the USB link. That is a small possibility the more I think about it. Other than that, the only other things I can think of are that the track maybe a stereo track, a mono track that isn't set to 44.1khz/16 bit, or the file name of the track might be too long for it to do anything with (as it is the old DOS FAT file name structure 8+3).
Just a couple of things to check over. I fell into the predicament of not being able to import files at first because I wasn't snapping to the fact that the tracks were in stereo, not mono. An easy way to split the tracks (if you don't want to combine the tracks into one) is to open the track in Audacity, Sonar, Sound Forge, etc. and simply copy and paste each channel (left/right) into a new file and name it. Viola! There are two mono tracks ready to import.
<insert witty and more appropriate comment here>
Old 06-02-2009
Registered User
I don't think its a timing issue before closing the USB as the file is definitely there.
I just checked file properties and I've been trying to import stereo. Thanks to both of you for spotting this problem. Hazards of being a new user to the hardware I guess. The manual is very explicit on importing .wav only and doesn't highlight mono only,
thanks and regards.
Old 06-02-2009
jjones1700's Avatar
Anytime man. Have fun with it. I love mine, just don't get much time to play with any of my recording stuff nowadays.
Old 06-03-2009
Arrow
Thank you. I'll try it some day. [MAGIX Music Studio]
Me too. Same here.
Old 06-03-2009
Arrow ...
[OT] I think I've thought of a way to record from the mic/line inputs directly to the DP02's Master track without recording to the tracking section [1-8] first.
It's an idea I had to try to create a mixdown master on the DP02cf from the 424mkIII Portastudio analog 4-track.
It's based on the idea that I'd get a more dynamic master track recording to the DP02cf than from my crappy soundcard.
It's not too detailed of a trick, but is as yet TBD.
Old 06-03-2009
jjones1700's Avatar
I'm eager to hear it. I'm still boggled by how people can bounce a number of times without accidentally wiping out a track in the process on the 424. I'll sit down one day and try to put down a simple tune on it. As of yet, it's been relegated to podcast duty.
How do I import files? jimistone Cubase User Forum 12 05-27-2007 22:55
Where is the "Import to Track" and "Import to Pool" Options studiomaster Cubase User Forum 4 05-03-2006 21:55
Bad day blues? (not blues) IanW-UK MP3 Mixing Clinic 30 09-29-2003 13:27
cant import cd trk. pattygram Cakewalk / Sonar Forum 7 05-02-2003 03:16
