Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 05-30-2009
trustify trustify is offline
Registered User
trustify is on a distinguished road
MXL 990 Records One Side
When I record on my MXL 990 condensor mic on cool edit pro it records only on one side either left or right so when i play back i only hear the vocal part left or right part of the speakers. I tired alot of things but can't make it into one.
Old 05-31-2009
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
to the left of each track is your track settings....you have an input button. when you click that, you are able to choose which input you want to record from. You also have the option of Right only, Left only, or stereo. if your track is recording on top, choose right only, and if its on the bottom choose left. Now when you record, you should end up with a mono track. I see this is your first post, and you are thinking that Im wrong, but you DO want a mono track....it will give you equal signal comming from each speaker.
Old 05-31-2009
Lt. Bob's Avatar
Lt. Bob Lt. Bob is online now
Spread the Daf!
Lt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond repute
yep
the 990 is a mono mic and has nothing to do with whether you get sound out of one side or the other.
Since it's a mono mic ...... there is no value in recording it to stereo even if you could.
Just record it as a mono track and at mixdown, you can pan it where you like.
Vocals usually go dead center anyway which makes them mono.
Thats it for me in this thread. I'll only eat the bait once .... voxxy
Old 05-31-2009
Registered User
hmm so whats the point of a mono mic then...i thought it was a decent mic to record both sides just wondering
Old 05-31-2009
mattr's Avatar
mattr mattr is offline
Resident stroppy teenager
mattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond repute
Because it gives you the most flexibility.
A lot of the time you only want to be recording a mono source, so it would be pointless and impractical to have a stereo mic. When you do need stereo, record with two mics. Recording in mono doesn't mean mixing in mono.
They do make stereo mics, but most people are happy setting up their own stereo pair! There are a few decent affordable ones like the Rode NT4 and some offerings from Audio Technica, but the really decent stereo mics are generally very expensive and aimed at situations like orchestral and theatrical recording. Even then they're generally used in mic arrays, trees, etc. With a stereo mic you're usually limited to what is effectively a XY coincident pair.
Old 05-31-2009
thajeremy's Avatar
registered abuser
with the settings you were using, the software was looking for a signal from 2 sources. You had your track set up as a stereo track. If you record one vocal track and have it dead center, you end up with the same sound comming from both speakers. If you have a stereo track where both the left and right side are the exact same track, then you are still in the same situation.....the same thing comming from both speakers...only with the stereo track, you are taking up twice as much harddrive space.
True stereo recording takes a stereo mic, which has 2 capsuls, or 2 independant mics....which is more commonly used.....even when recording with 2 mics, you typically do not use a single stereo track...most people record one source with 2 mics on to two mono tracks and then pan them later...
FS: MXL V67G, MXL 990, MXL 603, Morley Classic Wah Harlequin Man Free Ads for Music / Recording Equipment 3 01-03-2008 17:55
MXL 990 records strangely mbrown3391 Microphones 4 12-30-2007 17:02
MXL 990/MXL 991 Package any opinions gdavi1 Microphones 12 12-03-2007 18:41
MXL 2001 vs. MXL 990 for vocals/amps SMX_Dizzy Microphones 7 08-14-2006 00:42
Is there any point in buying MXL 603's if I have a couple of mxl 990's? Freudian Slip Microphones 13 06-04-2004 20:33
