Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 05-30-2009
MacGyver77 MacGyver77 is offline
Newbie
MacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond reputeMacGyver77 has a reputation beyond repute
Please help!
Okay so I've had a Tascam DP-02 CF for a while now, but am getting fed up with one thing. I have a Behringer C3 condenser microphone (laugh it up) which requires phantom power to run (as i'm sure you know). The only problem is, I have to crank the input level to the very max in order to get some sound, resulting in background fuzz being recorded because the input volume is so high. Could it be that my Mic is just a piece of crap? ALL ANSWERS APPRECIATED THANKS!
Old 05-30-2009
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Cranking it up like you say makes me think you are not getting the phantom power to the mic. Check and make sure you're using the right mic cord and and it's in the correct channel with the phantom power on. It looks like the DP-02 only gives phantom power to two of your channels.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 05-30-2009
jjones1700's Avatar
jjones1700 jjones1700 is offline
Learning, always learning
jjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond repute
The DP-02CF should handle phantom powered mics pretty well. It's the run of the mill dynamic mics that are the bane of that particular unit. I've run my AT-2020 (phantom power required) with no problems with gain.
Just MAKE SURE you have everything connected BEFORE you enable phantom power. Turn the DP-02 off when you want to disconnect the mic. It may sound extreme, but it will save you from possibly buying a new mic or a new portastudio (or a repair bill for the portastudio).
<insert witty and more appropriate comment here>
Old 05-31-2009
Good advice. Same problem with the 2488's.
Old 05-31-2009
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
Id never use a portastudio without an outboard preamp anyhow...the built in ones arent very good.
wayne
Old 05-31-2009
I have to disagree with you on this. The pre's on the 2488's are very good.
Old 06-01-2009
jjones1700's Avatar
As are the ones on the 424mkII.
