Phase cancellation
How important is it to avoid anti phasing in my mix. I mean, I know what it is and I know the results from serious phase cancellation but, just how much should I allow before I do something about it?
If you look at the picture I've posted, you can see some slight anti phasing but should I work to illiminate it? ![]() I've checked commercial mixes and most of them have some...amazingly, some commercial stuff constantly show stacks of it. I understand that the odd spike here n there is ok but is it really...I mean if I can work to illiminate it so that there's nothing outside the stereo space or out of phase, then should I do this or am I just being too picky? As I say, I understand that if there's a serious problem, then it has to go but these little spikes caused by 'stereo delaying' or reverb, should I allow some or should I work my socks off to illiminate all of it? Thanks... Mart. |
I would think if it already sounds great then don't even bother. After all, we don't see music, we hear it.
...but then again, mastering isn't really my area of expertise. Maybe SouthSIDEGlen or MassiveMastering will chime in on this ![]() |
There is no magic number to shoot for. The general rule of thumb when reading a standard L/R-style phase coherence meter is that if you're measurement is mostly hovering somewhere around (very roughly) 10-45% right coherence, that you've probably got a pretty normal and OK mix going. HOWEVER... This does not mean that there won't be swings over to the incoherence side of the meter on occasion, there most likely will be such swings just based on the laws of chance and probability, even in a "perfect" mix. This also does not mean that one necessarily *has to* shoot for that range, that those numbers indicate a recipe to be followed, because so much depends upon the actual musical content (or lack thereof). Some mix styles and genres are going to be naturally more or less coherent than others. As is so often the answer, the answer here is to use your ears to determine what's acceptable and what's not. There is a listening tool to help out with this, and that is to play the mix back in mono and see how well everything gets along. If any part(s) of your mix virtually disappear when you throwing everything to mono, you probably have too many phasing issues. Once you have a mix that sounds Ok in mono, you're probably OK. G. |
Thanks Glen.
Yea...I do compare in mono but this is what led me to my post. If it sounds ok in mono but I can still reduce the 'out of phase' peaks....should I do so at the expense of the stereo field...I mean, well I've just experimented whilst sitting on this thread.... I've tracked a piano in mono, well converted the wav to mono before importing to Reaper. Now, I want to widen this mono piano using a delay on the right channel. Now if I delay the right by around 15ms, I only get 1 or 2 dropouts max throughout the mix. Of course once I delay by 21ms which is where the widening really starts to happen IMO, I multiply the dropouts 3, 4 or 5 times. So my question really is....do I reduce the 'out of phase' peaks and sacrifce the width of the piano in the stereo field...or do I just go with what sounds best as long, as it sounds ok in mono ? Yes, I know the general rule is to listen with the ears and not the eyes but I just feel that when it comes to musical physics and laws....is it best to use abit of both. Sorry to be a pest but I just can't decide on this...go with what sounds best yes I know but...would sacrificing this little bit of piano width, help my mix to transport over wherever it's played...can this little difference of 6ms define a good mix to a bad mix. The widened piano sounds better to me but are these anti phased peaks telling me that it would actually sound better on other systems if I narrowed it? Fix it cause I can or, don't fix it cause it sounds ok in mono ? Yours, totally confused and undecided.... Mart. |
I'm not sure why you're collapsing your recording to mono and then widening it again. I assume that if you're collapsing your piano to mono that it must be starting out as a stereo mix either from a stereo out from an electronic keyboard or from stereo miking an acoustic piano. If that's the case, I don't understand why you collapse it to mono just to expand it again artificially. But whatever the case, if you're widening your image with phase tricks, you're pretty much going to be stuck with whatever you get in mono playback. As you have seen, it seems the wider the image, the more mono problems you may have. It's completely a subjective decision of your own as to how much you care about the mono playback and how much of one you want to sacrifice for the other. Personally I fall in the middle. I really don't care all that much about how my mix will sound played back on a clock radio or through the office Muzak system (unless the client does, of course); I consider the stereo image to be an essential artistic part of the mix, and if someone wishes to blind themselves to that part of my mix, and perhaps suffer some additional side effects in doing so, that's not my concern (unless the client says otherwise, of course ).On the other end of that issue, I am personally not a fan of artificial stereo expanders either; what many think sounds "k3wl" in that regard, I tend to find distracting and annoying (unless the client says otherwise, of course ). There sometimes can be some interesting things that can be done in that regard *with certain types of program content*, but only a small amount of what crosses my path is meant for the next Alan Parsons or Brian Eno psycho-acousti-delic treatment.This is all IMHO YMMV IME - unless the client says otherwise, of course .G. |
Cheers Glen.
Believe me mate, I'm not in the habit of collapsing my piano to mono. Piano is normally the main ingrediant of my music. I like my bass C to be slightly to the left and my highest C to be to the right. I just borrowed a Piano track from one of my mixes for the experiment. I backed it up and the mono version has since been deleted from my drive and will never rear it's ugly head again. I normally apply this stereo delay affect to synth sounds that I may create or to enrich a string section etc. I just used the piano to experiment with. I wanted it completely mono so that I could widen it to see how far I could go before seeing phase drop outs and with a Piano track normally containing shorter and more notes than strings etc, it's easier to tell the difference. I think though that it's artificial widening that causes the 'out of phase' peaks though, surely if we didn't widen or use reverb, there would be no dropouts and this thread wouldn't exist ? But yea, I think that I should start only widening things to the point of where they dropout and perhaps I'm right in thinking that if I can avoid the anti phase...then I should, reguardless of sound either in mono or stereo. Thanks Glen...you have been a big help. Mart. |
Phase differences are what make music and rooms and any stereo or binaural material enjoyable. The head related transfer function is based on amplitude and phase differences between the ears. So even a single source (perfectly coherent, duh) can sound great because of the phase differences. This is what can make the difference between a great concert hall and a terrible one. You can't really make blanket statements about phase cancellation is bad (unless we are talking like 180 degrees) always or anything like that, because the differences can make things so interesting. I use phase tricks all the time to not only widen the image, but to play interesting tricks. Just give it a go and see what you like.
I thought this was a fairly interesting thread that relates;
http://www.3daudioinc.com/3db/showth...t=17697&page=3 Quote:
![]() They also get into the folding in' of various mp3 rates that I wasn't aware of.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
WARNING: One of my looooong posts ahead
![]() Quote:
This means that any truly stereo signal - where there is any difference whatsoever between the left and right channel information - is going to measure as less than perfectly phase coherent most of the time, and is also bound to swing to the "anti-phase" side - i.e. register phase interference and even phase cancellation - at least part of the time. This will be true regardless of what the actual content is of the two channels. It doesn't have to be a time-based effect line delay or reverb; pumping a Di guitar through one side and a didgeridoo in a dead room on the other side is also going to provide some measure of coherence and incoherence on the meters, simply becaus ethe two waveforms are not going to be identical. I bring this up just to illustrate that the meters don't know and don't care what the source is or what kind of processing you're doing to them, it's just reporting the result. Just like a VU meter doesn't care what instrument you're playing, it just impartially reports the amplitude regardless of what it sounds like. Now, with delay, for example, the amount of incoherence (or "anti-phase", as your display calls it) depends greatly upon the dominant frequency of the signal as compared to the length of delay. As an over-simplified example, just to illustrate this point, let's say you have a pure 10kHz sine wave, meaning that the wave cycles from peak to peak and from trough to trough 10,000 times a second. If you through a 5ms delay at a copy of it, it will throw the copy 180° out of phase with the original, and if you sum the two together they will perfectly cancel each other out (full phase incoherence or full "anti phase"). If you increase the delay to 10ms, however, the two waves will once again line up - i.e. they will be fully coherent and complimentary. In-between delay values will result in in-between phase relationships and a mix of compliments and cancellations. Interestingly enough, if we change the frequency of the sine to 1kHz, the amount of phase coherence at 5ms and 10ms delay will be identical; they will both result in full 100% coherence. In fact any delay that is an exact multiple of 1ms, 3ms 7ms, etc. will give that result, since they all will wind up re-aligning the peaks with the original peaks and the new troughs with the original ones. It's only when we add fractions of milliseconds to the delay value (e.g. 10.5ms, 7.3ms, etc.) that we'll wind up throwith the new wave "out of phase" with the original. In the real world outside of a simple oscillator, however, with real world instruments like pianos and didgeridoos, the resulting waveform is going to be a mix of frequencies. The more complex the waveform, the harder it can be for the dominant frequency (like the fundamental note) to dominate the phase coherence calculations because there are so many other frequencies mucking up the purity of tone and adding to the unique timbre of that instrument. predicting just how increased or decreased delay times may affect the coherence calculations in such cases requires increasingly difficult math and and therefore an increasing degree of difficulty in predicting the result. It's much harder to determine just how a given amount of delay is going to affect a saxophone that it is a triangle strike. With that in mind, reverb can indeed muddy up the coherence because it involves both multiple reflections each with it's own amount of delay and a shift in frequency response over time (the high end tends to decay faster than the low end.) Thus it's often easier for heavily reverbed sounds to introduce phase problems than the identical non-reverbed signal. This is very similar to those who use electric guitar with heavy distortion, and why the headbangers on this board often seem to have more issues with phase than many of us geriatrics are used to seeing. When one is doubling and quadrupling Gibsons with heavily sustained power chords run through over-driven amps driving the tubes into non-linear distortions, it's a formula that can just scream "phase issues". (This is not an anti-genre point, jut a statement of the fact of the physics that have to be dealt with when dealing with that stuff.) Quote:
Cheers, Mart! Sorry about the looooong post (you should know that I'm prone to those by now :P) Good luck with your ivory tickling! ![]() G. |
Thanks Glen and please don't apologise for a detailed post mate...this is exactly the sort of full, well explained and informative type of stuff I signed up for.
![]() I hate one liners. ![]() Yea...I spent last night working on the mix I posted the picture from. I basically got it phase free all but a couple of spikes at the beginning. This was done by reducing hard panning, dropping certain stereo tracks to mono and then stretching them some, and a few other bits and dabs. It sounded ok but when I hit the mono button, the conversion was excellent compared to before. So I listened again today and the stereo mixed still sounded ok but then I thought...'ok?'...'it used to sound good'. So I took both versions of the mix and spliced them together at 16 bar intervals. When I listened, the original(widened) track was much better. Everytime I hit 16 bars of the new mix, everything went dull. So then I listened again in mono and guess what...it all sounded the same, I couldn't tell the difference from the original or the new mix when listening in mono. So then it dawned on me...when I hit the mono button whilst listening to the new mix, the conversion was only good because the stereo version was so narrow that is was almost mono anyway. When I hit the mono button while listening to the original mix, the jump was massive and I think this is what mislead me. So, in a nutshell...I eliminated the 'out of phase' peaks but the stereo mix wasn't so good....and I gained absolutely nothing for mono. So I've learned a valuable lesson now....not to let my eyes deceive my ears...or something along those lines. ![]() Thanks for your help mate. I understand phase issues alot more now and can move on. Mart. Now...where did I put that doppler? |
BINGO!
Well, it was coming towards you, but I think it's behind you by now...![]() G. |
#12
and this quote from it.... Quote:
Cheers
#13
The only way for two complex waves to be completely in-phase would be for them to be identical. The only way they could completely phase cancel would be if they were identical waves with one inverted. G. |
| why am i still getting phase cancellation? | mixaholic | Mixing / Mastering | 6 | 02-15-2007 14:33 |
| Phase cancellation | brainwashed | Mixing / Mastering | 14 | 09-07-2006 06:14 |
| Phase Cancellation | shreddist | Microphones | 8 | 06-22-2005 10:37 |
| Phase cancellation | Shack | Recording Techniques | 5 | 11-05-2004 16:57 |
| phase cancellation | grinder | Recording Techniques | 2 | 07-25-2003 23:48 |
