Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 05-27-2009
Victory Pete's Avatar
Victory Pete Victory Pete is offline
Thinking outside the box
Victory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond reputeVictory Pete has a reputation beyond repute
Angry Tape rubbing on TSR-8
For years my TSR-8 would frequently rub tape against the reels, I dismissed it to bent reels. Recently when I was trying to adjust the reel table height I noticed the hub wouldnt budge on the shaft. After frantically trying to get it to come off the shaft I noticed it had split. There is a cast Aluminum hub that fastens to the motor shaft with 2 set screws. The reel table is attached to this hub. The hub was machined out of spec and was too tight on the shaft and also was machined slightly too big to let the reel table sit on it perfectly flat, it was forced on and was always slightly crooked. I managed to have the hub machined so it would spin true. This is the disturbing part: I now own 4 TSR-8's and 3 of them had the same exact problem. 2 of my machines I found recently New In the Box. All 3 had the problem on only the take up reel side, the right hand reel. It obviously was a quality control problem they let slip by. So 3/4 of the machines I have had a problem with one hub. If anyone has experienced the annoying tape rubbing affliction you might have this same problem. It is fixable but not easy, I had to use a small pulley puller just to get the hub off the shaft, then you have to find a machinist who understands the problem. Of course Tascam doesnt make the hubs any more. The way to tell if you have this problem is to do this: Take off both reels. put a rubber band around the left tension arm and attach it to the idler roller, this will spin the capstan. Now press play. With your finger gently feel the edge of the reel table and feel for vibrations, if you have this problem it will be obvious, you will feel the edge of the reel table oscillating.
I hate to be the messenger, but some of those machines out there must have the same problem I have had. The date codes range from 1992 through 1993. The 3 digits following the serial number is the date code. 921 means 1992 first quarter. Let me know what you think.
Thanks
VP
Old 05-27-2009
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
Tape?...where do you even buy tape...I have an old Akai deck...but I cannot find 1/2" tape for it.
wayne
Old 05-28-2009
Thumbs up Rmgi 911
RMGI has been making tape for some time now. It is great stuff, the 911 is 456 compatible and I think is sounds better than 456 ever did. U.S recording sells it. There are other dealers also. The future looks great for Analog
VP
Old 05-28-2009
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
I think you're looking for 1/4" tape and not 1/2". I've never seen an AKAI deck take 1/2". Which model do you own, may I ask? But yeah, like VP mentioned, RMGI (who took over from EMTEC / BASF) makes tape again and word is that QUANTEGY will restart production soon.
Other than US Recording Media (among other vendors), where you can buy new tape, look on eBay for sealed Maxell UD.
Old 05-28-2009
RRuskin RRuskin is offline
Rick Ruskin
RRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond repute
Originally Posted by cjacek View Post
.................and word is that QUANTEGY will restart production soon.
That word has been around so long it's beginning to get kinda ripe and smelly. I doubt that they will get production going again for quite some time if ever again. Times being what they are. My opinion only.
Rick Ruskin
Lion Dog Music - Seattle WA
http://liondogmusic.com
Old 05-28-2009
It can play 1/4 inch...but for all 4 tracks you need 1/2"...and sorry...it was a TEAC.
wayne
Old 05-29-2009
cjacek's Avatar
Analogue Enthusiast
Sorry but I'm not sure what you're saying. You mean that the TEAC that you have is 1/4" but that, generally speaking, 1/2" is preferable for 4 tracks?
Old 05-29-2009
cjacek's Avatar
Analogue Enthusiast
Well, I'll choose to be optimistic but, yer right, that "word" is indeed taking its sweet time...
Old 05-29-2009
Thumbs down Let sleeping dogs lie!
I wouldn't want to hold my breath waiting for that to happen. I have more faith in RMGI who is a company that apparently still believes in analog, than a lazy old American company who threw in the towel. I used Ampex and Quantegy 456 and it never sounded as good as RMGI 911 does right now.
VP
Old 05-30-2009
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Not nearly as long at this point as RMGI and ATR after their initial press releases.
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 05-31-2009
cjacek's Avatar
Analogue Enthusiast
Bloody good point.
Where to buy Tape for Tascam TSR-8 Christopher11 Analog Only 2 10-01-2008 10:11
Analog Rig*tascam Tsr-8 Tape Recorder*allen Heath Mixer*plus Extras! kensington Free Ads for Music / Recording Equipment 6 08-30-2008 10:43
What tape for tsr 8??? smuffjules TASCAM User Forum 5 03-21-2006 23:50
How do you stop tape rubbing on Tascam 38 SteveMac Analog Only 4 09-22-2004 14:48
Tape Rubbing on Reel The Analog Kid Analog Only 9 06-30-2004 00:34
