Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-27-2009
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
Gapless Audio CDs
Just wondering how you stitch together PCM WAVs into a gapless audio CD. Is there a utility that can do this? I use Audition as my DAW and thought I might be able to with this, but I haven't found it yet.
I'd like to record live DJ sets and then split them appropriately, but still be able to burn to disc as if it was listening to a live DJ performance.
Thanks
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 05-27-2009
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Originally Posted by TimOBrien View Post
There may be free tools out there, but the 800lb gorilla is Sony's "CD Architect".
(I got it free with Soundforge but you can get it separately.)
Powerful tool....
Yep. I have CDA 5.2 - you can even crossfade tracks.
If not, nero lets you set the gap to zero, and it;s free I believe.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 05-27-2009
Mart[1001]'s Avatar
Mart[1001] Mart[1001] is offline
Senior Member
Mart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond reputeMart[1001] has a reputation beyond repute
So you load two wavs into Audition. Then you copy the second wav into your clipboard or even better, select cut so that it leaves the window empty(to use later), but stores the wav in your clipboard...then find a suitable place in the first wav toward the end where you'd like the second track to cross fade, mark the position with your mouse and then select 'paste and mix' or simular command so that you then have one big wav containing the two tracks. You must used 'mix' though else you'll just wipe the end of the first tune.
Now you select a point where you'd like the first track to end and the second one to start and highlight this area until the end of the wav so you in effect, have the second part of the wav selected. Now select cut which will delete this section of wav from your original and store it in your clipboard. So now you paste this into a new window or even the old one if it's still there and now you have two wavs again only now, the end of the first has the start of the second and you guessed it...the start of the second has the end of the first joined with it.
Now it's just a case of saving off the two wavs as track01 and track02 and then burning to CD. You'll be able to select either track from the CD but if you leave track 1 till the end...it will seemlessly join into track two.
Now there's every chance I lost you a long time ago but if you kept a clear head and paused and thought while reading this, then there's every chance you've got it.
I really can't think of a better way to explain though without actually showing you with some sort of youtube tutorial but really, it ain't half as hard as it sounds...just think about it and it'll happen.
Mart.
Old 05-27-2009
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Powerful tool....
Old 05-27-2009
Bristol Posse's Avatar
Bristol Posse Bristol Posse is offline
Dedicated Member
Bristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond reputeBristol Posse has a reputation beyond repute
+1 for CD Architect
Easy to do exactly what you ask here and a whole lot more
Creating gapless transitions between tracks... layneness Mixing / Mastering 9 12-18-2007 07:21
Creating gapless transitions between tracks... layneness Mixing / Mastering 1 12-13-2007 12:21
Audio-only CDs!!?? Roker1 Newbies 2 08-08-2002 18:11
Audio Sample Cds? soundboy Keyboards and Sound Modules 2 11-09-2001 07:41
Playback of Audio CDs ateizzynuff Newbies 6 05-15-2000 18:31
