dp002 cf set to
i am wondering when i am doing a set to, set in, set out, when moving parts of something, how can i get to my set to end point to insert a new set to without going to it from the beginning of my recording.
Can't you punch the out mark and get to the new time/measure from there?
<insert witty and more appropriate comment here>
but maybe i should look into that because the jog is very time consuming, how could i do that? |
You can change what time/measure increment you are jogging with to save a little time shuffling back and forth. Use your left/right arrows to select either minutes/seconds/frames, then use the jog wheel to move forward or back in a tune. Likewise, if you are in the beat/measures mode, you can go left/right to select which variable to jog up and down on.
| TASCAM DP002 CF mastering. | j.w | TASCAM User Forum | 3 | 05-26-2009 19:01 |
| Which set should I keep ?... | gilwe | Drums and Percussion | 8 | 01-14-2007 06:04 |
| Lost on how to set up drum set on cpu | bonz6969 | Newbies | 0 | 03-24-2006 21:26 |
| how would this set up be...... | bad intentionz | Digital Recording & Computers | 1 | 12-05-2005 19:38 |
| rhythm set and performancce set | mikerenwick | Roland, Boss, VS Series Forum | 1 | 01-27-2000 21:32 |
