Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 05-25-2009
jkbutler jkbutler is offline
Registered User
jkbutler is on a distinguished road
Digitech GNX 3
I have one and it is great for looping but eats up alot of the memory for a full song. DOES ANYONE HAVE ONE AND HAS CONNECTED TO THEIR COMPUTER AND HOW? I AM COMPUTER STUPID!
Old 05-25-2009
mcmetal mcmetal is offline
Senior Member
mcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond repute
I have a gnx2 but i've never hooked it up to my computer.I went to the digitech website and seen on the forums there that a lot of folks had trouble with their saved settings getting wiped out when they tried to download stuff from the site.Maybe it was just gnx2 specific.It was a few ago and has probably been resolved by now.The gnx3 has the built in 8 track right?You may be able to send your data to your computer by the spdif jack or the midi out.
According to my manual if using the spdif you connect your spdif output to the spdif input of your recording device.Since your using your computer you'll probably need some kind of adapter to plug into your soundcard.
If you have the GenEdit Editor/librarian software you need to connect your computer's midi output to the gnx midi input and the gnx midi output to the computer's midi input.Then after hooking everything up you need to stick the disc into your computer and follow the install intructions.
Also if using the spdif you'll have to adjust your digital output level found in the utility mode to avoid clipping.
My gnx2 has the dry track feature also found in the utility mode which allows you to record an processed signal.Using dry track 1 allows the pickup modeling up to the noise gate but bypasses modulation,delay and reverb.Dry track 2 allows a completely dry signal tapped off the input jack.You can then take the unprocessed signal and feed it back into the input for reamping through different amp models
Most of this info came from my manual but i'm sure it applies to the gnx3 as well.You just got more bells and whistles then i do.hope it helps.I suggest visiting the digitech website.you'll get more feedback there.I'm sure the forums there will be able to help you out much more.
Digitech Gnx 1 For Sale Or Trade JonKauffman8 Free Ads for Music / Recording Equipment 0 12-03-2004 19:55
Digitech GNX series patch forum 7evin Guitars and Basses 0 11-19-2003 15:16
Digitech GNX? gamut1 Other Equipment and Reviews 1 05-09-2001 20:19
Digitech GNX gamut1 Guitars and Basses 0 05-03-2001 13:44
Digitech montage The Rack 0 07-27-2000 10:43
