Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-22-2009
matthew_a matthew_a is offline
Newbie
matthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond reputematthew_a has a reputation beyond repute
Best way to mix straight from file off a laptop?
Hi, I'm looking for wisdom on the best low-key setup for mixing my music in Cubase. I just finished a full solo album and used a set of decent computer speakers+sub to mix, as well as various headphones and testing it on other platforms, etc. But I want to upgrade my home-recording/producing rig with some studio monitors and probably a new firewire interface, etc. for my next few projects. SO my question is: whats the best signal chain for mixing from a computer? My current plan is to just run a firewire interface like a Motu 8pre or Focusrite Saffire Pro 40 off my PC (Dell Latitude D830, going to upgrade to macbook pro ASAP), then run the main 1/4inch outs to a pair of powered studio monitors, or maybe unpowered through an amp or whatnot.
The reason I'm asking about this is because my current interface is a Presonus Audiobox USB (piece of crap), and the outs, both the mains and the stereo headphone out are terrible, very tinny and no bass response. I would never want to run serious mix through it, so I'm understandably leary about running a mix through a new interface, even if it's a better one than my crappy Audiobox. Thanks, hope this wasn't too confusing. Peace
Old 05-22-2009
gecko zzed's Avatar
gecko zzed gecko zzed is offline
audio illusion
gecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond repute
If you are not getting a good sound through your audiobox then the chances are high that there is something amiss with your monitoring signal path. It is less likely that the fault lies directly with the audiobox.
For example, it sounds to me that you might be getting a mixture of two near-identical signals that's causing low end phase cancellation. Perhaps you have both software and hardware monitoring occuring.
I have a theory about that
Old 05-26-2009
Newbie
Thanks for the advice, I think you're on the money with that. The audiobox has a headphone monitor control nob that switches between the inputs and playback from the computer, allowing me to mix what I hear...but I usually monitor any inputs I need to hear straight from Cubase. This sounds like it could be the problem. Do you have any suggestions on how to correct this, or is the Audiobox just cursed with this feature? Thanks
Matthew
Old 05-26-2009
gecko zzed's Avatar
audio illusion
Matthew
I think you are generally better off not monitoring straight from Cubase, and instead using the the monitoring functionality of the Audiobox.
Best way to mix audio straight from file from a laptop? matthew_a Digital Recording & Computers 0 05-22-2009 11:56
File Moves in Mix After Recording RTWmaniac Cool Edit Pro / Adobe Audition Forum 0 02-27-2009 14:23
Need to host 757MB file for a mix shootout jndietz MP3 Mixing Clinic 0 12-08-2007 15:37
Straight ahead Rock tune- Please critique mix Bartman MP3 Mixing Clinic 3 03-12-2007 11:33
Final sound card output go straight to .wav file? specklebird Digital Recording & Computers 0 02-23-2000 01:48
