Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-20-2009
Robertt8 Robertt8 is offline
1K Silver Member
Robertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond repute
Question If limited to 2 effects to mix, what would you choose?
If you could only use two effects to mix, what would you use and why?
Old 05-20-2009
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Reverb and delay.
Reverb for the sense of space, you can run anything that needs it into the same verb and it will sound ok.
Delay for the lead vocal and lead guitar just as an effect. You can use the same setting for both, just use more of it on one than the other.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 05-20-2009
jimmi jimmi is offline
Junior Member
jimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond reputejimmi has a reputation beyond repute
Originally Posted by Farview View Post
Reverb and delay.
Yeah definately reverb and delay. For those exact reasons. Reverb, used right, to make everything gel together and sound natural. Delay to add complexity and grab a bit more of your attention.
In fact I rarely use much else after tracking.
Old 05-20-2009
1K Silver Member
you wouldn't have compression as one of those effects?
Old 05-20-2009
RD423 RD423 is offline
Dedicated Member
RD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond reputeRD423 has a reputation beyond repute
hard 2 pick just 2, but I can give u 3 in the order that I use them.
Compression-EQ-Reverb.
Pro Tools forum
Old 05-20-2009
witzendoz's Avatar
witzendoz witzendoz is offline
Senior Member
witzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond repute
Hi,
I don't consider compression and eq as effects, I would call that processing.
Effects: Reverb and delay.
Cheers
Alan.
Old 05-21-2009
Seafroggys Seafroggys is offline
Force of Nature
Seafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond repute
Delay could be done by copying tracks and offsetting them.
EQ and Compressor for me. If I need verb, I'll just mic a speaker in a bathroom.
Old 05-21-2009
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
I'd use the air conditioner and lava lamp effect cause it gets hot and dark in here sometimes.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 05-21-2009
Waltz Mastering's Avatar
Waltz Mastering Waltz Mastering is offline
Senior Member
Waltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond reputeWaltz Mastering has a reputation beyond repute
Originally Posted by witzendoz View Post
Hi,
Any effect would be considered processing. DSP, ASP.
Tom W
Affordable High Quality Mastering - Worldwide
http://waltzmastering.com
waltzmastering@gmail.com
Old 05-21-2009
iownrocknroll iownrocknroll is offline
Dedicated Member
iownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond repute
EQ and Compression.
I could use the room as natural verb, which I prefer anyways. And there are tons of ways to get "delay" then using a processor.
Old 05-21-2009
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is online now
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Haas and Doppler. Because they're the only effects I can think of off the top of my head.
I don't understand what the OP considers an "effect". While all effects are processing, not all processing can be considered an "effect". If we're talking about processing in general, I'd have to say fader automation and multi-parametric EQ. If we're talking sound effects, reverb is the only one I can think of that I care to use.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
  #12
Old 05-21-2009
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Just record the band at Madison Square Garden and forgo all effects...
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
  #13
Old 05-21-2009
Farview's Avatar
That depends. Are you asking because you have a 'studio in a box' that only lets you run two things on the effects card? (in which case 'effects' would include compression, eq, and any other processing)
If so, I would have to go with EQ and compression. Of course, if you only get one instance of an EQ or compressor, that's pretty useless. I'd probably go back to my original answer in that case.
Jay Walsh
  #14
Old 05-21-2009
1K Silver Member
no, it's more of a hypothetical question aimed at looking at what most people consider "must have" items when it comes to mixing.
I've been screwing around with some mixing lately after a long break and just kind of getting some juices moving.
two mix effects orksnork Mixing / Mastering 8 08-05-2006 20:46
Mix-down effects MikeST Analog Only 3 03-14-2005 17:39
effects you use to mix your tracks jayphon Cool Edit Pro / Adobe Audition Forum 7 03-23-2004 11:51
VF-16 Limited to just 2 effects at mixdown? rbw87 Fostex Forum 7 03-03-2002 16:22
why can't I get my effects to work during mix down cheeserocker Mixing / Mastering 1 07-14-1999 12:29
