Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 05-19-2009
googlydog googlydog is offline
Newbie
googlydog is on a distinguished road
Intonation help
Trying to adjust the intonation on my wife's short scale bass.
It's a weird old frankenstein of different parts, does not seem to have the original neck or bridge.
The intonation is way off. She can tune the strings and have the intonation look fine by checking the harmonics on the 12th fret, but when she actually goes to play any note on any string, it's way sharp. It doesn't matter how close to or far away from the headstock or bridge she's playing, it's always around the same amount off... which is a lot.
The bridge is an old thing where the only movable part is a bar that goes up or down, to adjust the action, but not back or forth. How could I possibly make the intonation better?
I would REALLY appreciate any help and tips for what I can do at home.
Old 05-19-2009
ocnor's Avatar
ocnor ocnor is offline
Lord Of The Thighs
ocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond repute
There's the problem. You don't set the intonation using harmonics.
Old 05-19-2009
mcmetal mcmetal is offline
Senior Member
mcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond repute
If you can't adjust the length of each string you'll have a hard time if it's even possible.You would normally tune your open strings then check the tuning on the 12th fret.By adjusting the length of the string is how you adjust whether it's sharp or flat at the 12th fret.It should hold in tune on both open strings and at the 12th fret when it's intonation is set properly.Raising or lowering your action shouldn't make a difference.I suggest changing the bridge to one that allows you to adjust the string length if she really likes this bass.I know for a fact that if the intonation is off above the 12th fret you'll hear it go out of tune if you play above the 12th fret while recording.check out www.projectguitar.com they have some good tutorials on setting up guitars
Old 05-20-2009
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
You mentioned some parts had been changed, possibly the bridge also. Start by checking to see if the bridge is in the correct place. Use a good metal tape measure and check the distance from the 12th fret to the nut, then the distance from the 12th fret to the bridge. Both measurements should be very cloce to the same. With a fixed bridge (like what you described) the 12th fret to bridge will likely be slightly more on the low E and A, slightly less on the D and G. Replacing the bridge with an adjustable one is not usualy a difficult mod, it just takes being careful to get it in the right position. If you are in doubt, a guitar tech can do it fairly fast and should not cost too much to have one installed. Since you mentioned all the notes being sharp the bridge is likely to be a little bit too cloce to the neck.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
Old 05-20-2009
Newbie
Yeah, seems like I'll have to replace the bridge. She really likes the bass, since it's short scale it's much easier for her to play than a full-sized bass.
The tuning is as far off on the 12th fret as it is on any other fret. I was reading somewhere that it can get further off the further up the neck you go, but that's not the case on this.
Wish I wouldn't have started fiddling with this three days before an overseas tour... whoops!
Old 05-20-2009
ermghoti ermghoti is offline
1K Silver Member
ermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond repute
Not true. Raising the action, the notes will get sharper, and moreso towards the bridge, lowering causes the inverse. Since this bass is always the same amount out, it's not the action, the bridge (or maybe the nut*) is misplaced.
* If the nut is wrong, tuning the open string to a tuner would put every fret off by pretty much exactly the same amount. This could be the culprit.
Old 05-20-2009
ido1957's Avatar
ido1957 ido1957 is offline
4K Silver Member
ido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond repute
Install a new bridge that can be intonated....
G M P
H S B
Old 05-20-2009
Senior Member
Obviously raising the bridge would sharpen the notes and lowering it would flatten them.There's these things on the headstock called tuning pegs and they should be adjusted after making any adjustments.It doesn't matter where the action is set.It's up to each individual player and their preference and playing style.Once the action is set up to their liking then set the intonation.Like i said intonation is determined by adjusting the length of the string.String height has nothing to do with it.
Old 05-21-2009
1K Silver Member
You are wrong. The height of the bridge has more effect on notes near it, just like the depth of the nut slots have more effect on the frets near it. No amount of tuning or lateral saddle adjustment will change that. For example, most new guitars have shallow nut slots, and the first few frets are quite sharp as a result. Bridge height is more forgiving, because of the much greater distance to the last fret, compared to the nut/first fret difference. In any case, you can either fiddle with the saddle and reach a compromise, or you can adjust the bridge and/or nut.
A lot of people compromise intonation to get ideal action, I prefer the other way around.
Old 05-23-2009
Senior Member
Maybe i'm wrong but it's nothing i've had ever had to compromise with.I adjust my action to my liking and adjust my intonation accordingly.I've never had any issues.I don't check every note on every string on every fret of my guitar with a tuner to see that everythings absolutely on.I check my open string tuning and check on the 12th fret and adjust as needed.I've been doing this for years and never had tuning issues.
When my old band recorded some years ago my bass player didn't take the time to check his intonation.On a few songs when he played above the 12th fret you could hear his bass go out of tune.When he played below the 12th fret he sounded fine but you could hear him go in and out of tune throughout the song.That bothers me every time i listen to it and that's why i gave the advice i did to the OP.Playing live i never noticed it,i'm sure maybe others did but when recorded it really stuck out.
I stick with my original advice and think the OP should put on a new fully adjustable bridge and like dani said measure the distance from the nut to the 12th fret and so on.If the holes don't line up right he can fill in the holes and drill new ones.This was done to one of my guitars where the original trem was replaced with a floyd rose,the original holes were filled with a black epoxy or something and were redrilled to accomodate the new trem.It holds it's intonation with no problems and after years of playing it i 've never had any issues with the filler and trem coming loose.
Old 05-23-2009
muttley600's Avatar
muttley600 muttley600 is offline
The Central Scrutinizer
muttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond reputemuttley600 has a reputation beyond repute
You are incorrect. Read links in my signature.
Originally Posted by wheelema View Post
Guess I was wrong!
  #12
Old 05-24-2009
1K Silver Member
Well, here's the thing: making sure that the 12th fret fretted note is the same as the 12th fret harmonic is not really intonating. Chances are, you're using at least adequately-made guitars, which will be somewhat intonated using that shortcut, but I guarantee if you form a three or four note chord shape, it will be quite noticably out by the time you're at the fifteenth fret or so.
Or, you could d.l. a strobe simulator, and see how far some off the notes will be. The first couple of frets will be sharp, the high frets will fall all over the place, most likely.
Check Muttley's links.
If all the notes are equally out, as the OP describes, it can't be the bridge, the notes would be progressively out as they neared the bridge, since the percentage of misplacement changes as you shorten the vibrating string length.
  #13
Old 05-24-2009
Senior Member
Guess i'm never too old to learn something new.I'll have to check out the links
  #14
Old 05-26-2009
Tadpui Tadpui is offline
Force of Nature
Tadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond repute
Care to expand on that?
________________________________________________________________
Everyone's a voyeur, they're watching me watch them watch me right now
  #15
Old 05-26-2009
muttley600's Avatar
Read the links in my signature.
To those links I'll just add that setting the individual string intonation using the 12th fret harmonic method is really just the start of the process. Because of the way tuning temperament and physics works you need to be aware of many other things that result in implications for tuning and intonating an instrument.
Guess I was wrong!
  #16
Old 05-26-2009
six's Avatar
six six is offline
Y'I know...
six has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond reputesix has a reputation beyond repute
I read the "how to tune your guitar" link, and at first I thought "hey, this might make sense" - but no, I cannot agree with most of what is said.
What's said about tuning to the 5th produced as a harmonic over the 7th fret sounds sensible, but the part about the 3rd in your chords sounding either slightly flat or slightly sharp depending on whether they're minor or major - with a "correctly" tuned guitar of course - really made me doubt about this concept. Hello? It's the same string. So the same C# would once sound flat and once sharp just because it's played once in an Amaj and once in an Bmin... yeah, sure.
Plug your guitar into a tuner, use open strings or 12th fret harmonics, be happy. Lately I've even used the "beginner method" a lot: tune your low E to the tuner and fret it in the 5th fret for you A and so on...
www.soundclick.com/sixch
six.ch.to
  #17
Old 05-26-2009
muttley600's Avatar
you clearly haven't understood. It is not a concept it is fact. The interval in the two chords you describe are not the same. That is the whole point. Keep in mind that the description and explanations in that link are given by some of the worlds best and most experienced luthiers and is based on in depth knowledge of musical acoustics, an understanding of ancient and modern temperaments and the instruments that those limitations are placed upon.
You can of course use whatever method of tuning you choose but that will not help those that can identify dissonance in many of the chords they play and the OP who wants to understand why his bass will not play in tune.
Guess I was wrong!
  #18
Old 05-26-2009
Senior Member
I read through those links once before.Yes,it makes sense and i was one those guys for years that had always heard the g string sound a little sharp and would tune it down a slight bit.By doing this it would in fact alter some of the other chords.I noticed it on most open chords that use the g string.
Most times if i was playing something with a lot of open chords i would leave the g string alone.I think if you're playing just a lot of distorted fifth chords you probably won't notice it as much but the clean channel doesn't lie.
Whenever i set my intonation i always use an electronic tuner.I always tune the open strings and then check it on the 12th fret but i've always fretted on the 12th.I've never set it by using 12th fret harmonics.It's the same note so does it make a big difference whether fretting the 12th or using the harmonic?
  #19
Old 05-27-2009
six's Avatar
six six is offline
Y'I know...
With "concept" I was referring to the method they describe to actually tune the guitar.
It's most definitely not due to the way he tunes the bass, not only because it's not about chords with dissonances but single strings that don't produce the note they should when fretted.
@mcmetal:
When setting the intonation, of course you have to _fret_ the note in the 12th fret. A harmonic will always be the exact octave to the empty string, no matter how badly set the intonation is. The fretted note then has to match the harmonic.
six.ch.to
  #20
Old 05-27-2009
muttley600's Avatar
And that method or a similar one will ALWAYS produce a better intonated guitar in 12 ET. That is the fact part.
I was pointing out that your advice and comment was both incorrect and of no relevance to the OP. I stand by that. The discussion had moved into discussion about intonation and temperament in general. You have made some comments that are incorrect and I was pointing that out. This is another one
@mcmetal:
It is not always the best way to set up a guitar to intonate in 12 ET. it is a good start point.
To fully understand intonation, temperament and the physics of a vibrating string requires that you read and understand the links in my sig. Denying that they are correct or in some way flawed is just plain wrong.
Carry on.
Guess I was wrong!
  #21
Old 05-29-2009
six's Avatar
six six is offline
Y'I know...
ok, ok, muttley... I read it again and had to realize, it's actually not much that is said, and the bit that is said is of course true. but it's so damn sexed up that I got distracted by the fillers.
Nevertheless, I'm still convinced of three things that do not contradict this article:
1st - Tuning your guitar by using open strings and tuner you can pretty much do without the knowledge of tempered and non-tempered intervalls and the tuning method mentioned. You'll stay in the tempered world.
2nd - If you don't have a tuner, you can use the beginner-method (which doesn't rely on harmonics) and you won't leave the tempered world either.
3rd - The whole knowledge about tempered and non-tempered intervalls, scales or instruments doesn't solve the OP's problem, which is very obviously a wrongly set up or - worse - built instrument.
Read http://hubpages.com/hub/Equal-Temperament-Guitar-Tuning under "Testing your instrument":
"[...] but if every stopped string is equally sharp (or flat), you may indeed have an ill-made instrument. [...]"
six.ch.to
  #22
Old 05-29-2009
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
... So the same C# would once sound flat and once sharp just because it's played once in an Amaj and once in an Bmin... yeah, sure...
The same note certainly can sound sharp in one chord and flat in another. It's a different context.
Gordon in Austin
http://www.crystalflavola.com
  #23
Old 05-30-2009
six's Avatar
six six is offline
Y'I know...
apart from the fact that I clearly misread the part I was referring to (it doesn't even say this), it's a bit of a relative question but I still say this can't be the case with a guitar tuned to equal temperament. and I repeat: it wasn't mentioned like this in the article.
Actually we have to be more precise: it can SOUND once sharp and once flat, but it can't BE. If it sounds once sharp and once flat in the mentioned chords, it has to be due to the other strings that ARE flat or sharp. But due to the way a guitar is built, in this case it would either sound flat in both cases or sharp in both cases.
Anyway. You've kind of stated the obvious. But not having a different context with every other chord is basically the point of the equal temperament.
six.ch.to
intonation FALKEN Guitars and Basses 24 05-20-2007 17:54
Intonation GoldFalcon Guitars and Basses 7 08-27-2005 08:13
Intonation? ecktronic Guitars and Basses 4 12-06-2004 17:50
Intonation Imaduck Guitars and Basses 41 09-14-2004 06:01
intonation matty_boy Guitars and Basses 8 09-21-2003 20:24
