Old 05-14-2009
expatCanuck's Avatar
expatCanuck expatCanuck is offline
Newbie
expatCanuck is on a distinguished road
low-end recording equipment upgrade
Greetings -
I'm a simple guy with simple needs -- recording acoustic strings (guitar/mando/banjo)
and vocals, one track at a time. I also would like to hook up MIDI out from
our Roland F-90.
My current home recording setup uses an AT2020 or SM-57 into a MobilePre,
thence to a homegrown PC (single-core Athlon 3000+, 1MB RAM, modern SATA drive,
WinXP Pro). Good enough to run Audacity, Reaper, Music Creator or the like).
But I do like to play with harmony vocals, and find that when I layer vocals,
things can start to get muddy.
So I'm considering an upgrade. Overlooking, for the moment, my own inability
as a songwriter, performer and recording engineer, I'd expect the (next) weakest
technical link to be the MobilePre.
I've read conflicting opinions as to whether, from a sonic perspective, it would be worth
moving to the $250-$400 product class (e.g. - Echo Gina3G, FA-66, Saffire LE).
I'd certainly welcome opinions in this regard.
At the very top of my budget (okay -- a bit beyond my budget) are the FMR RNP
or BLA Auteur. Now, if I purchase one of those units, I certainly can't also afford
anything along the lines of the BLA Sparrow or any other such AD for some time.
(And I'd need a DA unit as well, anyway)
So, would it at all make sense to pair an RNP/Auteur-class preamp with an AD/DA unit
along the lines of, say the EMU1212? A comparably cost-effective alternative?
Or might I just as well use the converter in my MobilePre?
But does it even make sense to do that -- wouldn't the weak AD/DA
kill any advantage in the good preamp?
Thoughts, suggestions, questions or other aid in curing the analysis paralysis welcome.
Thanks kindly.
- Richard
oldWithoutMoney.com
Old 05-14-2009
tdukex tdukex is offline
Man of the Muse
tdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond repute
Originally Posted by expatCanuck View Post
Greetings -
our Roland F-90.
Thanks kindly.
- Richard
oldWithoutMoney.com
I haven't heard the Mobile Pre, but IMO the EMU 1212 IMO would be a definite ADA upgrade, and the DMP3 would also be a noticable upgrade over the preamps in the MP.
Old 05-14-2009
witzendoz's Avatar
witzendoz witzendoz is offline
Senior Member
witzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond repute
You have not mentioned the acoustics of where you record, it could be that as you layer the acoustics of you space are adding to the mud.
If your recording space has no acoustic treatment maybe you should budget to improve the space before buying more gear. A small amount spent in this area can improve recordings heaps.
Cheers
Alan.
Old 05-14-2009
jaz49 jaz49 is offline
Senior Member
jaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond reputejaz49 has a reputation beyond repute
+1 Assuming you have done some room treatment, the converters in the emu 0404 are supposed to be first rate. A guy I know who has over 20 yrs. studio experience speaks highly of this unit. The preamps aren't at all bad either, until you can afford an outboard pre. My situation is similar to yours and I often use the 0404 with no other pre. I tried a vtb-1, but I wound up preferring the pres in the emu.
http://www.myspace.com/lejaz
Old 05-15-2009
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
Id limit it to three layers...and pan them so they spread across the stage...that will get rid of the muddy...you are singing the same on each track right?...thats what Id do.
wayne
Old 05-15-2009
Newbie
Ummm --- nope.
At times, 1-4 background vocals.
BTW - op, ks, eh?
I spent 7-8 months working in Overland Park in 2004, and loved spending my evenings at Doc Fuller's open mikes (the Peanut & Peanut north). I certainly do miss hearing him, Alan White, Jeanne & Jenny.
Cheers.
- Richard
Old 05-15-2009
kojdogg's Avatar
kojdogg kojdogg is offline
bollocks redux!
kojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond repute
Well, please take this all with a grain of salt because I just listed on some iPod ear buds plugged into very crappy computer speakers (as opposed to my Adam A7's or Sennheiser HD600's at home ), but it's a very sparse arrangement-- just ac guitar and vocals and IMHO it doesn't necessarily sound "muddy"-- a description often associated with excessive or distorted bass/midrange, but there are several vocal tracks fighting for the same space and not much of a musical bed/foundation to stand on. Personally, I might try beefing up the acoustic track by turning it up a little bit, maybe a bit of compression and a touch of eq on the lead vocal track and guitar (no more than a couple of db of either) and then some subtractive eq on the background vocals (a low cut to start-- maybe a dramatic one to thin them out a bit) and maybe turning them down a little bit so they don't have equal weight to the primary melody volume-wise. The panning idea for the bg vocals is a good idea too.-- in general everything seems bunched up in the center. A stereo expander plugin or reverb used with great discretion might help.
I reserve the right to take back all of these suggestions if I listen to your track with better monitoring later though...
SPACE AVAILABLE FOR RENT
Old 05-15-2009
Newbie
Originally Posted by kojdogg View Post
Well, please take this all with a grain of salt ...
No need to take anything back. I'm reasonably new to recording, certainly new to mixing, and the tune is a sketch in its infancy (a neonate, in fact).
I welcome any thoughtful advice, and yours clearly is.
Cheers.
- Richard
Old 05-15-2009
omtayslick omtayslick is offline
1K Silver Member
omtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond repute
Yup, pan 'em and spread 'em out. Then thin them with eq if nessesary. The individual sounds aren't bad. As was already said they're just fighting for the same space.
Tom
Old 05-15-2009
Ummm --- nope.
BTW - op, ks, eh?
Cheers.
- Richard
I havent been to the peanut...watching gay men dance with each other isnt my thing.
just kidding...I was there the night when the TV exploded.
wayne
Old 05-18-2009
guitar junkie's Avatar
guitar junkie guitar junkie is offline
Guitar User.
guitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond repute
Yup panning and reverb is what can make vocals sound cleaner, L R and Center works great as well as M/S encoding but I don't wanna blow your mind yet...
In all honesty a good quiet preamp can be made to sound many ways it's the noise issues that always kill me...
Save the money and buy something really nice, but if you must buy something than a a DMP3 might well serve you some use.
My various rants about digital audio and Indie music: At my blog
  #12
Old 05-19-2009
Weasel9992 Weasel9992 is offline
Force of Nature
Weasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond reputeWeasel9992 has a reputation beyond repute
Cheers
Alan.
It's pretty much impossible to make anything sound good in a bad room no matter how good you are or how great your equipment is. A small, untreated room will definitely sound muddy.
Frank
GIK Acoustics
www.gikacoustics.com
  #13
Old 05-19-2009
Shadow_7's Avatar
Shadow_7 Shadow_7 is online now
Dedicated Member
Shadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond reputeShadow_7 has a reputation beyond repute
The mobile pre is not that best thing out there. I have one. I pretty much only use it to interface my laptop with my stereo system. To record from a tape player, or just to capture things off of a radio. My Delta 44 is way better. And my Korg MR-1000 is way better than the 44. If I were to quantize it, it'd be like Mobile Pre is 60% as good as the 44. And the 44 is 40% as good as the MR-1000. Rough guesstimates anyway.
To phrase it another way. When I got the Mobile Pre, it was like cool I can do this stuff now. When I got my Delta 44 I was like holy cow my CDs never sounded so good. When I got my Korg MR-1000, I was like CDs suck. Where can I buy DVD-A's.
  #14
Old 06-03-2009
Newbie
I ended up buying a used combo: Symetrix SX202 & Delta 44.
Seems to work pretty well. Here's a clip from the maiden voyage:
vocals --> SM57 --> SX202 --> Delta 44 --> Audacity --> .wav --> .mp3 (via LAME)
SM57test-GoldenRibbonsRefrain.mp3
Sounds one heck of a lot nicer than through the mobilePre.
I just love cheap & effective.
- Richard
oldWithoutMoney.com
is low end Pentium 4 okay for recording? daddymac Digital Recording & Computers 6 07-19-2006 09:40
Is this the ultimate low-low-end recording solution? cominginsecond Digital Recording & Computers 25 02-13-2004 13:12
Does guitars low end and Bass low end tend to fight for the same low end? videodrone Recording Techniques 15 04-28-2003 13:48
tape decks: low end sansui vs. low end teac MrLip Analog Only 5 07-07-2000 04:32
Absolute Low end recording- i need HELP!!!! Guitaranddrummer Newbies 2 07-01-1999 12:19
