Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 04-28-2009
stevieb stevieb is offline
1K Silver Member
stevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond repute
Gear Review: Altair PW-5 Attenuator (A TRUE Attenuator)
Scored one of these at a musician's swap meet I attend in Nashville last weekend. The vendor wanted $50 for it, but traded for a couple of cabs I had- we both got something we wanted. Lots of folks looked at it, and I was quite suprised it was still there when we made our swap- turns out it's only good for up to about 50 watts, which is why it was still on his table at about 2 pm. Lucky me.
In the last few years, I have found myself going to smaller and smaller amplifiers, in an attempt to have the tone I seek while not blasting everyone around out of the room. That quest had brought me through (not exactly in chronological order, but rather in approximate decreasing power):
Fender Twin Reverb (later, 135-watt version),
Gallien Kruger 200G- 100 watts,
GK 250ML, 100 watts,
Fender Pro Reverb- 60 watts
Ampeg VT-40- 40 watts
Peavey Classic 30 and a Delta Blues 210- both 30 watts,
Fender Deluxe Reverb- 20 watts,
Peavey Bravo 112- also 20 watts,
Fender Super Champ XD- 15 watts,
Fender Vibro Champ- 6 watts (borrowed from a friend)
Alamo Challenger 6 watts (borrowed from same friend)
Pignose 100- who knows? 5 watts?
Monkey-Wards Model 6000- 3 watts.
It wasn't until I got to 15 watts and under that I had any success in my dual goal of good tube tone and reasonable volume. I had heard a lot about attenuators, and was glad to have the chance to get one without a big outlay of cash (I had very little invested in the cabs...)
If you have never used an attenuator, imagine this- you know how a car sounds so much better when the motor is really working hard? You only get that sweet sound when you are either flying at zero altitude, which gets you a hefty speeding ticket, sooner or later, or when pulling a trailer. An attenuator is the amplifier equivelant of that trailer behind your Boss 302 Mustang- it makes the "vehicle" work harder, and a by-product is that sweet tone.
This is really the grand-daddy of all attenuators. No, really- it was the first commercially-available attenuator made, and they date back to the 70's. The Marshall Power Brake, with it's silly psudo-rack mount look (http://guitargeek.com/gearview/879/), and the THD Hot Plate, with it's California-Cutesy purple case (http://guitargeek.com/gearview/1072/) are both reportedly based on the PW-5. In comparison, the Altair looks like an escapee from a radio control room. I kinda like it's "honest" look- but if I had one of the others, who's to say I wouldn't prefer that look? It is built like the proverbial tank- you could use it if the tour bus had a flat on a hill and you needed to chock the wheel so the bus would not roll off the jack. It really appears to be that robust- the all-metal case is made of some very thick stuff. Attenuators do their work by producing heat, which MUST be dissapated- this one does so passively, with lots of ambient air flow through the multitude of holes in it's cover. It has a true by-pass switch, which takes the whole thing out of the circuit, and a HUGE attenuator knob, with 11 detents, each one reducing the power that goes to the speaker (by about 50%, I suspect.) It has a single 1/4-inch input jack and two output jacks, and a line output with a 3-way pad switch, with 0, -15 and -30 settings- very neat feature.
In use, this is a good device to have. Using it with the SCXD and the Deluxe Reverb, I can "dime" the volume control on the amp and select the volume level I want with the PW5's attenuator knob. With these two amps, the upper 6 or 7 settings are useless- way too much attenuation, which results in a overly-compressed sound, devoid of almost all highs, but the first 5 or so settings gives me that power-tube "growl" that gets attention- but now with tone instead of volume. I find that the volume controls at every other point in the signal- guitar, pre-amp gain, power-amp volume- are not as touchy when the PW5 is standin' on the brakes. I have had mixed results with master volumes, either ones built into an amp, or the add-on's that plug into the effects loop (one of those recently reviewed here on Homerecording.com)- they do reduce the volume (well, DUH!) but don't make the power tubes really work for a living- only an attenuator (or a stack of speakers) can do that. Thus, I prefer a true attenuator, like this PW5. Still, there is no free lunch- heavy attenuation will degrade the signal, so it's best to use a low setting, and tube life is no doubt reduced- you are working your power tubes harder, so of course they will not last as long.
Rarely do I get hooked in by a new piece of gear the first time I use it, but this is one of those rare times. Perhaps the best use of this, or any true attenuator, is if you are not sure how much power you will need at a gig or rehersal- bring too small an amp, you will struggle to be heard, bring too big an amp bring an amp and you never get into the amp's sweet spot. Bring a bigger amp and an attenuator, and be ready for any contingency. I will probably bring this one, and my Deluxe, to my too-big guitar group rehersal this week, but after that I will probably bring the SCXD or my buddy's Vibro Champ, simply because they weigh so much less. (Last night, I almost rigged up an RCA-to-quarter inch cord to try it with the VC, but decided that would just be silly. Yeah, like I've never done anything like that...)
Should EVERYBODY have one of these? Well, no. If you have a low-power amp you are happy with, attenuating it would be silly. The occasional amp (Fender's Deluxe Recording, for instance) has one built in, thus no need for an out-board attenuator. But they do work better then low-level devices (master volume, effects-loop add-on), and, used with some restraint, can help your amp deliver the tone you bought it for, in the first place, at a volume that does not have everybody saying "WHAT DID YOU SAY? I CAN'T HEAR YOU FOR THE RINGING IN MY EARS!!"
Old 04-28-2009
Tadpui Tadpui is offline
Force of Nature
Tadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond repute
I love my HotPlate, couldn't live without it with an 80-watt tube 2x12 combo. Gotta love the sound of a tube power section being pushed to the brink!
Oh, and the HotPlates come in a variety of colors depending on the resistance you choose. I have the 4 Ohm version and its red/magenta. They always show the 8 Ohm version in catalogs, which is the purple one I believe.
The same thing happens with the HotPlate at extreme attenuation levels. They really strangle the amp's tone. At least it has the bright and deep switches to replace some of the elements of tone that are stripped away, but even then its still pretty squished.
Honestly I don't understand why everybody with a tube amp over 5 watts doesn't have an attenuator! Heck, even a 5-watter could use some attenuation from time to time.
________________________________________________________________
Everyone's a voyeur, they're watching me watch them watch me right now
Old 04-28-2009
c7sus's Avatar
c7sus c7sus is offline
Disenfranchised Member
c7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond repute
Uh....... THD is located in Seattle.
I bought my kid a 50w Weber MASS Lite to use with his Blues Jr amp. Device works great and my kid is able to crank nasty tones out of the amp at bedroom volume.
Old 04-28-2009
Roguetitan's Avatar
Roguetitan Roguetitan is offline
The Poly Grip Kid
Roguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond repute
Thumbs up
Ya that is what I use on my Peavey Valve king. Good and affordable attenuators.
Until This Day
Old 01-08-2010
ira_numan's Avatar
ira_numan ira_numan is offline
Newbie
ira_numan is on a distinguished road
Rogue et al,
I'm new to the tube tribe, having purchased/stolen a PV Classic 212 (not VT, from the '80s) and was wondering: until I can afford two-hundred-plus dollar attenuator or a significant mod to my amp, what would be an acceptable solution to keep peace in the house? The very reason I got the 212 was, aside from the buck-and-half estate sale price tag, the reviews I've stumbled upon in search of an affordable tuber. This amp is the bomb. It has "the sound" AND IT'S REALLY LOUD!
I was looking at "The Little Sucker" and the "Output Tamer" (which has a mild treb boost which I thought was nice and it gets mucho positive feedback).
Any input would be welcomed!
Peace, y'all!
Eric
If given the opportunity to start over, I think I'd learn to read.
Old 01-08-2010
mshilarious's Avatar
mshilarious mshilarious is offline
Narwhal of Death
mshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond reputemshilarious has a reputation beyond repute
Originally Posted by ira_numan View Post
Rogue et al,
Eric
http://www.parts-express.com/pe/show...number=260-265
Old 01-08-2010
Roguetitan's Avatar
The Poly Grip Kid
an omnisonic will work but you have to go through the amps EFX send and return if the amp dont have a EFX send/Return you will need to get an attenuator.
Until This Day
Old 05-26-2010
borrows123 borrows123 is offline
Registered User
borrows123 is on a distinguished road
I am not pretty much sure about that..
What else we can say....
Start to your career with the world accredited 640-801. For a guaranteed up to date set of questions for 642-383. offers complete ccna 640-802 and 640-816.
Omnisonic Preamp attenuator Review Roguetitan Guitars and Basses 5 04-25-2009 14:55
Using and attenuator with Yellowjackets. capnkid Guitars and Basses 4 05-06-2007 05:20
Best attenuator Elmo89m Guitars and Basses 18 11-29-2005 12:43
attenuator pads... thajeremy Microphones 15 06-26-2005 18:05
attenuator pads chessrock Microphones 9 01-10-2003 15:21
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
