Celotex Soundstop
Hi, has anyone here ever come across or had any experience with Celotex Sound-stop fibreboard in regards to isolation. I was at a supply yard getting acoustical caulk and the guy there asked me if I wanted some, here is a link with some info on it.
http://www.soundstop.net/documentati...aspx#soundstop [/URL] any info would be greatly appreciated thanks Nick.
"It's great to be here. well it's great to be anywhere really". |
I don't know about that stuff but I've heard great things about Green Glue.
Myriad Rocker My Web Design/Production Company: Myriad Productions My Band: Black Leaf Clover |
The pdf's make the product look like you would be dumb not to buy it. A friend of mine used it in an isolation booth build about a month ago, honestly, my drum room isolates sound better than his booth. He used the method shown in their pdf that advertises 60+ db reduction in sound transference. (Single stud wall design 4.5" thick). He spent twice as much as I did on my double stud wall (12" thick, 2.25" decoupled slot between the 2 frames).
You will find that there is no replacement for mass when trying to reduce sound bleed. But, who knows... YMMV. |
What's the point in using Green Glue in a single wall system? You aren't going to get much isolation that way. You're still transferring the energy that way. Green Glue works better (and has been tested to) in a 2 leaf system. And it works better in a 2 leaf system than a 2 leaf system without it.
![]() Quote:
Green glue is designed to make TWO or more LAYERS of drywall act as ONE complete layer(I believe it changes the "incidence dip")...as in 2 layers of 5/8" drywall act as one integeral layer 1 1/4" thick. This can be on a ONE LEAF or TWO LEAF system..it doesn't matter. What DOES matter, is two things. That a wall assembly IS TWO LEAF, regardless if it is a SINGLE or DOUBLE framing assembly. In a SINGLE assembly, both leafs are connected via studs, with a single airgap. This is whats known as a MAM system. i.e ..MASS/AIR/MASS. So is a DOUBLE framing/2 leaf assembly. The main differences are a deeper airgap, and one leaf is "decoupled" from the other by virtue of seperate framing systems. Regardless of the type framing OR number of leaves, Greenglue will make 2 layers perform better than two layers without it.
alright breaks over, back on your heads! |
Rick, have you ever been told you're one touchy dude? ![]()
Thanks Guys for the replies, I guess I'll just go with the 1/2" plywood. The guy quoted me $11.20 for an 8"x4" of the celotex which I thought was a good price, if it did what they said in the PDF's, I just don't want to make a blunder at this part of the build (stud level) my original plan was to do 1/2" plywood then peacemaker by audimute finished with 5/8" drywall.
Thanks Nick.
I have thought it quietly to myself while reading his responces to people. But after reading hundreds of threads in which he has offered help, I began to understand (to a degree) why the posts sound snarkey... He has been posting the same information over and over, sometimes 2+ times a day, for many a year. I would most likely become abrasive too if I were in his place.
He has the information though, and his willingness to help nublets - even with an air of condescension - greatly outweighs his blatant disregard for human emotion. ![]() ![]() ![]() fitZ has been around the block a few times, who knows what could have happened to him on one of those trips?! ![]() |
![]() I'm Irish...whatta ya expect?![]() But let me give you some insight into my character...I'm 64, Irish, married, semi-retired, pissed at the mods for not giving any attention to this forum by making stickys..FOR YEARS...even though I've posted a zillion drawings showing MOST everything there is about building studios, I smoke, drink, and generally am a cranky old crudgmudgen who doesn't give a flying fuck what anyone thinks, cause my work here speaks for itself. PERIOD. I may fly off the handle sometimes, but mostly I'm good natured...untill SOMEONE pushes a button. I'm an expert CAD/3d person, a journeyman MILLWORK detailer/builder, a 40 yr guitarist, 20 yr home recordist and I don't pull punches, cause in the real world, around real peers...they don't either. So get a thicker skin dudes. ![]()
#12
Oh, the skin is plenty thick. That's why I took your context with a grain of salt. Notice I said context, not content.
#13
btw, I saw your post at John Sayers site. Hmmmm, maybe you've got more irons in the fire than I figured.![]()
#14
PM me with requests. peace.
Find my tunes here >>> http://www.soundclick.com/bands/page...?bandID=741321 |
#15
Wow! I had no idea you were the mod here. Great!Quote:
![]() Ok, heres the deal. I have literally tons of detailed drawings, to scale, with many views in the form of a Studio Isolation/construction assembly set, Geometry set, Treatment set, Detail set, Millwork/Fixture building set, Idea sets including how to's(machining, materials, products layouts) and Diamond Theory set, Equipment/Wiring set, and a few more. These are in Sketchup 3D jpeg format as well as links to my own hosted Sketchup .skp files(models) for loading into peoples own Sketchup program for viewing as well as altering for their own purposes. Not to mention links to the Sketchup 3d Warehouse for downloading literally thousands of usefull PRE-DRAWN models relevant to Home Studio building. I'll post a few on a thread for you to view and decide. If you want to see the complete sets, let me know. However, I'm still in the process of reformating and compressing these sets, and compiling the set links. Anyway, thanks for the offer. I'll be posting a few of these in the next few days. fitZ ![]()
#16
I think you had a sketchup tutorial somewhere. I wouldn't mind that being a sticky also. I have tried my hand at it and I can't get the quality drawing that you have posted. Let's do this through PM's instead of hijacking someone's thread. ![]() Cool!!
#17
Hey Rick, just wanted to say wasup and thanks for all your insight- we are almost finished with our building, and I applied some of your techniques. I am glad this opp came along for you as well, it is neat to watch it unfold.
Listen to my music @ www.myspace.com/michaeldaltoncountry |
| Homosote=Celotex? | alba123 | Studio Building & Display | 0 | 04-10-2005 08:08 |
| Celotex | darnold | Studio Building & Display | 2 | 10-16-2002 10:57 |
| Celotex Soundstop - any good? | PetSoundsPSU | Studio Building & Display | 1 | 08-03-2001 14:56 |
