Old 04-22-2009
doulos24 doulos24 is offline
Dedicated Member
doulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond reputedoulos24 has a reputation beyond repute
pvc pipe celing project budget $100
ok this is nuts I've gone off the deep end this time. I've made a semi angled celing out of pvc pipe covering the mix position. I'm just geting started this is the frame work for the celing. I'm going to suspend acoustic celing tiles fixed to some thin plywood or similar to give me a reflection free celing any ideas welcome. I've spent 42 dollars so far and I'm taking about 5 of it back in stuff I haven't used so I have about 65 I can throw at this so any ideas are welcome
I did a stress test and with the wall braced design I was able to hold up 5 7 foot long 2 by 4s with very little bending and the miricale of them all with that design i actully can and did put it together by myself :P
I refuse to be the nice guy. Do you want to get better or have everyone tell you you're awesome?
Old 04-22-2009
braden_'s Avatar
braden_ braden_ is offline
Junior Member
braden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond reputebraden_ has a reputation beyond repute
why so low?
Old 04-22-2009
stevieb stevieb is offline
1K Silver Member
stevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond repute
I don't think pvc pipe will support the weight of even the thinnest plywood you can find. I'd try to find something much lighter, you don't want your ceiling falling down on you...
Old 04-22-2009
KineticSound's Avatar
KineticSound KineticSound is offline
The VOICE
KineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond repute
Just a thought... I used foam-core board (from an art supply store) as a support backing for some acoustic panels I made a couple months ago. The 3/8" foam board is stiff enough to hold shape, but very light and very inexpensive. It's also very easy to attach acoustic foam with a little spray adhesive.
I posted a pictorial of the project here: http://homerecording.com/bbs/showthread.php?t=279020
I could easily see someone adapting the same principle to a larger panel that could sit on top of your PVC "frame."
David Swinehart
Owner / Operator
Old 04-22-2009
Dedicated Member
because its angled and against the wall I'm about positive I could at least go with 1/2 inch thick plywood without any problem this is not the flimsy flexable pvc pipe its pretty rigid stuff.
why so low?
they didnt have it in 10 feet lengths so i had to use 5 feet pieces I'm thinking of taking it up another foot or so but I don't think it's necessary do you guys? I thought once its covered its like having infinant high celings?
Old 04-22-2009
1K Silver Member
Hey, you're there and I'm not. But if I DO get there, I don't think I'm gonna stand under that thing...
Old 04-22-2009
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Nope. All you're doing is making an even smaller box.
Old 04-22-2009
Dedicated Member
um not from what ive been told but will see dont asume i dont have any bass traps or side reflections this is just for the celing
Old 04-23-2009
Dedicated Member
update
double post
Old 04-23-2009
Dedicated Member
update
ok I'm done I think. I changed the design a bit and added more bracing to it I just mounted the acoustic panels to the pvc pipes with zip ties but it works
went from the frame to this
Old 04-23-2009
witzendoz's Avatar
witzendoz witzendoz is offline
Senior Member
witzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond reputewitzendoz has a reputation beyond repute
Why don't you hang a cloud off the ceiling and forget the frame altogether?
I angled my clouds (frames).
There is a thread on the building on my studio here, the later photos show the clouds (acoustic panels) hanging from the ceiling both in the control room and studio. They work really well. I think in the thread I described the construction of the clouds.
http://homerecording.com/bbs/showthr...ight=witzendoz
Cheers
Alan
  #12
Old 04-23-2009
Dedicated Member
I really thought that why would be the most obvious. I'm not allowed to drill into the celing where I'm at, so I made a free standing one to the best of my ability
  #13
Old 04-23-2009
witzendoz's Avatar
Senior Member
You did not say this. OK in that case put the frame up higher, right hard against the ceiling, and hang the cloud from it, only a couple of inches (50 mm) below the frame.
I see the frame is bending under the weight, Run a second PVC pipe (horizontal pipes) under the first and tie them together with cable ties.
Cheers
Alan.
  #14
Old 04-24-2009
Dedicated Member
the pipes arn't bending the center supports are 1.5 inch the frame is 1.25 and the frame is about 2 inches higher so they are angled a lil. This fame can support my body weight. I did add another 1.5 inch center beam centered on the back wall, but it really isnt needed. What's the advantage of taking the celing higher asuming the celing has full sound absortion? The nrc of these tiles are .55 say I got the total nrc to be 1.0 by adding a full layer of unfaced r-19 on top 6.5 inches thick I'm guessing that should put the new nrc value over 1.0 with the tiles. If I did this would there be any advantage to going higher? my understanding is when you pass a nrc of 1.0 it's like having very high celings at the mix position
Unfaced 6.25" R19 on wall 0.64 at 125hz 1.14 250hz 1.09 500hz 0.99 1000hz 1.00 2000hz 1.21 4000hz 1.05 nrc
plus .55 nrc of the acoustic tiles that should theoretically = insanely high celings correct?
  #15
Old 06-05-2009
mrhotapples mrhotapples is offline
Dedicated Member
mrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond repute
Do you have absorption at the first reflection points on the walls? That's just as important if you want accurate stereo. I like the rolls of insulation in the corner, lol. I've got bags of Cocoon fill in the corners with some 2" panels standing on them, stradling the corner. It works amazing but I'm going to buy some LENRD bas traps to put in the other corners because they look cool and they'll still help + I don't have to worry about mounting them. I too cannot drill into the walls/ceiling and won't even be living here for more than a month.
  #16
Old 06-08-2009
chugheshc chugheshc is offline
Senior Member
chugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond repute
Are those rigid fiberglass acoustic ceiling tiles with facing on them?
If they are, then you have them upside down for what you are trying to achieve. (the facing is opaque to sound - it will reflect!)
If they are not the rigid fiberglass, then I am not sure what effect they will have on your acoustics.
3/4" of absorption is not really very much.
If you are attempting to provide an "infinite ceiling" sort of thing, you are going to need something more in the order of 18" to 30" of depth of RF to begin to approximate this.
Working around attaching things to the ceiling is probably a bad idea; it's ineffective at best, hazardous at worst, and really, really bad looking no matter what you do.
You might want to concentrate on learning how to mix in the environment you have to deal with, until you have a proper space.
best of luck!
Chris
home of the cheap
land of the improvised
  #17
Old 06-08-2009
1K Silver Member
Just came to this thread to see if it has fallen on the OP yet...
  #18
Old 06-08-2009
J-Lane J-Lane is offline
Newbie
J-Lane is on a distinguished road
I'm sure if they have Wi-Fi at his local ER he will give us an update.
  #19
Old 06-09-2009
1K Silver Member
Hey, cut they guy some slack, chugheshc. He DID admit, right off, that
ok this is nuts I've gone off the deep end this time...
project mixing upgrade 1,000 budget doulos24 Mixing / Mastering 0 04-03-2009 08:23
MIDI help - Pipe Organ project!!! mshilarious MIDI Mania 19 08-23-2007 16:09
Celing Joist insulation savageblues Studio Building & Display 3 04-01-2005 10:54
Help with recording project on a college student budget paperhatrecords Recording Techniques 6 03-29-2005 15:07
$50,000 Budget - How's this project studio sound? u2bonoman Newbies 17 09-10-2004 05:38
