Go Back   Home Recording > User Forums by Brand > Emagic / Logic Forum
Reply    Audiofanzine Apple emagic Apple emagic News Apple emagic Medias Apple emagic Tests Apple emagic Articles Apple emagic User Reviews Apple emagic Classifieds Ads
Old 04-12-2009
wtferk wtferk is offline
Registered User
wtferk is on a distinguished road
cant hear midi
Hello, im new to logic,
ive got leopard with logic 8 installed,
got a midi keyboard and the signal is working and i can see the channels graph goin up and down,
HOWEVER, i cant hear the midi, Audio works fine, and i hear everything
what to do about that ?
thanks
Old 04-13-2009
billmcdonald's Avatar
billmcdonald billmcdonald is offline
Senior Member
billmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond repute
When you say "midi keyboard" do you mean a keyboard hooked up to a midi interface via midi cables or are you coming out of your keyboard usb to your computer?
Old 04-13-2009
didgijimmy's Avatar
didgijimmy didgijimmy is offline
vexed
didgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond repute
I went through this when I began to test the mideival midi waters. Others may be better suited to this but since you haven't had any suggestions I'll give it to you in a nutshell.
1. A "midi" signal is not audio. What you are sending via your keyboard to pc is an electronic signal with instructions. Basically it's a code your pc reads that tells how long to hold a note and I believe the volume, among other things. However there is no audio being sent to your pc, that is why you have some meter action but no sound.
2. In order to get sounds from your midi signal you must have what are called VST plugins installed to your DAW. These are virtual instruments, same as on your keyboard, that are plugged into the midi signal giving you sound.
3. The advantage of using midi is that numerous voicings can be applied to the same rhythm. Also, unwanted notes may be erased, and other things can also be adjusted.
4. If you insist on getting the sounds from your pc there is a roundabout way of doing it but it is a lengthy process and I won't talk about it in this post. If you want info search: edrum midi= confusion city, into the search function at the top of the screen. This is a post I made when trying to understand midi and I believe you willl find instructions on this process made by altitude and Chilli (be sure to rep). This brings me to my final point,
5. Welcome to HR. Many here are very willing and enjoy helping those new to subjects. All any of us ask is that you try the search function first, you will get results faster, and avoid clogging up the BBS as many questions have been asked before.
Happy posting,
James
Old 04-14-2009
Registered User
lol weird
its fixed, i can hear midi sounds and i audio sounds
and my midi keyboard connected via midi to usb connector
and usb to the computer
Can't hear MIDI recording. theschaef Recording Techniques 5 12-01-2007 09:00
Can't hear midi pepsiguy Digital Recording & Computers 10 12-01-2006 09:30
can't hear midi sounds! redheadedboy MIDI Mania 7 01-05-2002 21:45
can't hear midi sounds! redheadedboy Cakewalk / Sonar Forum 4 01-05-2002 20:45
cant hear midi sir ludwig Cakewalk / Sonar Forum 2 09-24-2001 16:48
