Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 04-11-2009
Kroy Kroy is offline
Newbie
Kroy is on a distinguished road
Recorderman sounds very mono. Is this right?
I threw up a couple of 421s in recorderman. Then I panned both channels hard left and right. The result sounds really quite mono. Is this the way it's supposed to sound? I tried flipping phase on one channel and it sounds like my brains are being sucked out of my head so that's not the solution. The drums sound great though. Very punchy. But is it supposed to sound this mono?
Old 04-11-2009
RAMI's Avatar
RAMI RAMI is online now
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Not at all. There's something weird going on if it is. Recorderman should give you a nice stereo spread on your toms, hats, cymbals, etc....Of course, your snare and kik should come right up the middle, though.
Old 04-11-2009
RAMI's Avatar
www.ramirami.com
Flipping the phase will sound weird, as you discovered. The reason we measure the exact same distance from the snare/kik and the mics is to keep them in phase.
Old 04-11-2009
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
Need more info on your signal chain and crap ....
What are you recording to? digital, analog ...
How are you monitoring?
~It all works out in the end~
Old 04-11-2009
drossfile's Avatar
drossfile drossfile is offline
custom title FAIL
drossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond repute
it does seem strange. i have to wonder if using dynamics has anything to do with it. after all, they're going to be less sensitive and as a result maybe the differences in relative volumes going to each mic is less noticable than using condensers...idk, i'm just speculating out loud.
you should try doing a scratch track where you slowly strike each component of the kit, like a sound check, and listen back. if your floor tom sounds like it's in the exact same location in the stereo field as your hi-hat, then something else is going on (such as monitoring or inputs, as crankz is suggesting).
i only pan 3 and 9 o'clock, and my stereo spread is very wide. hard panning should make the different positions pretty obvious.
can you post a pic of your setup? if it's small and you have it tightly put together it could conceivably narrow the field. idk, again just speculating...
dross
Old 04-12-2009
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
Wait, recorderman? or Glyn Johns?
I always thought recorderman couldn't end up anything but mono.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
Old 04-12-2009
Newbie
Thanks for the replies.
I accidentally recorded each mic to both tracks!
It sounds good though. Even though it's very mono it's also very punchy and focussed. I'll add this to my accidentally discovered arsenal of tricks.
The 421s sound good as OVs.
Old 04-12-2009
RAMI's Avatar
www.ramirami.com
No, it should end up stereo, too.
Old 04-12-2009
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
The goal of Recorderman is to be mono for the kick and snare, but stereo for the rest of the kit. But it's not an exaggerated stereo spread. I have to think that using 421s has something to do with this though--they are going to have less transient response and less high-frequency response than a condenser. That information is critical for stereo location. While 421s might sound good in a different, more widely spread configuration (where there are more phase differences to create a stereo image), they might just be a bad match with Recorderman.
You might try a modified Recorderman that rotates the mics counterclockwise (looking down at the kit), a bit more towards the ride for the right rear mic and the hat for the front left mic. The kick and snare will go slightly out of phase between the two mics, but it should still be acceptable. Heck, it might even help.
Another thing to try is stay with Recorderman, but toe the mics towards ride and hat. There you are taking advantage of the directionality of the 421's response, while still keeping the low- and mid- frequency info from the kick and snare intact and in phase. The danger here is the loss of high frequencies from the crash cymbal, so I probably would be hesitant to try that with rock music. Could work well for jazz.
Old 04-12-2009
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Originally Posted by mshilarious View Post
.. I have to think that using 421s has something to do with this though--. .
I think someone hasen't had his coffee yet..
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Last edited by mixsit; 04-12-2009 at 09:51.. Reason: you'd think i could spell coffee too..
Old 04-12-2009
ermghoti ermghoti is offline
1K Silver Member
ermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond repute
That would do it.
Nah, it'd sound the same in stereo, only... stereo.
That, on the other hand, is a useful bit of trivia.
Mixing in mono...it always sounds like crap TylerDrums109 Mixing / Mastering 40 02-14-2009 11:05
First take ever at recorderman method gdavi1 Drums and Percussion 16 01-28-2008 15:34
recorderman toobalicious Microphones 3 01-25-2008 10:21
Mono overhead almost sounds stereo??? HangDawg Drums and Percussion 8 01-30-2005 09:33
