Old 04-08-2009
JG96's Avatar
JG96 JG96 is offline
Casual Poster
JG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond reputeJG96 has a reputation beyond repute
DIY sub kick
i wana build a subkick kinda design i dont wana spend that much i have a 8 inch speaker from a broken amp. how would i go about building this? has anyone here done this before?
Old 04-08-2009
Dogbreath's Avatar
Dogbreath Dogbreath is offline
stayin upwind
Dogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond repute
Yeah...I built one out of a cheap Radio Shack sub.
Not hard at all. The hard part is mounting it. I happened to have one of those adjustable armed snare stands that I collapsed to where the three arms cradled the speakers magnet, then zip tied it in place.
I took one of my XLR cables, chopped an end (make sure you pick the right end ) and wired the + of the cable to the - on the speaker. Vice versa for the other and then took the common ground (probably just copper wire) and wired it straight to the speaker chassis. Take a file to the paint on the speaker if you need to...just to make sure you get a good connection.
One other thing that's a "must" is an inline pad. Maybe called an attenuator. I found one from Shure that's adjustable from -15, -20 and -25. The signal coming out of the subkick is HOT. You'll want to damp it down before it gets to the preamp.
I think I might still have some pics around if you're interested.
Peace.........Kel
dribbling footballs
http://www.myspace.com/doghausrecords
Old 04-08-2009
Dogbreath's Avatar
stayin upwind
Try this thread...
http://homerecording.com/bbs/showthread.php?t=277728
they be pics in thar...
dribbling footballs
Old 04-08-2009
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
Yup ... I did somethin' like it as well here at Ghostnote.
Well, it starts out with an internal mic mount and evolves to the sub-kick.
I'm still dinkin' with it.
~It all works out in the end~
Old 04-09-2009
Minion Minion is offline
Blow Me !!!
Minion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond repute
I mounted the speaker for my subkick in an old 10in Tom I had ...
I left the skin on it but tuned it really low and mounted the speaker in the tom on the open side ...
I mounted the speaker in the tom useing some elastic bands , sort of like a shock mount for a mic ....
I drilled a hole in the tom and mounted a XLR Jack , I then mounted the tom on an old cymbol stand and put it in front of the hole in my Bass drum .....
At First i had problems with my Preamp oscilateing because of the Low 4 ohm source impedance so I connected a center tapped 1/100 audio transformer to the speaker and then to the XLR and it worked perfectly .....
It sounds good but I only used an 8 in speaker and think a bigger speaker would sound better and I used a subwoofer which seems to put out a frequency that is too low for my likeing ....
Cheers
War is just a word used to hide the nakedness of their killing ......
Kwai Chang Caine
(Kung Fu)
Old 04-11-2009
JG96's Avatar
Casual Poster
thanks everyone this now seems like a very easy project and fun too wheres a good place to buy a drum shell to mount it in though
Old 11-22-2009
RogerRecords RogerRecords is offline
Registered User
RogerRecords is on a distinguished road
SWEET! Can't wait to get this project going. Should be a fun one for us this winter break. I'll post updates and how it went once were up and running with it.
Old 04-13-2010
steve7680768 steve7680768 is offline
Newbie
steve7680768 is on a distinguished road
I have never heard of it...
But now I got it and will try to get the best solution for you,..
4A0-103 and 640-460 preparation especially for 640-553 and 640-721.
Old 04-13-2010
Dogbreath's Avatar
stayin upwind
dribbling footballs
Old 04-13-2010
moresound's Avatar
moresound moresound is offline
Loud Sun Studios
moresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond reputemoresound has a reputation beyond repute
Look under the microphone forum under "home made sub kick mic" a lot of pictures and a lot of helpful info. I believe that it is still on the first page.
I have a fever and the cure is cowbell ..........*LIVE FREE OR DIE*
Old 04-13-2010
ranjam's Avatar
ranjam ranjam is offline
Senior Member
ranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond reputeranjam has a reputation beyond repute
I put the Pearl mesh heads on mine. They let the sound through, and protect the driver as well. I knocked the grommet out of the shell, and a 1/4" jack fit perfectly in there. You might need the jack to have a long thread, but those are available easily enough. What else? The tom mount can fit on a desk top mic stand. Or just chop a junk mic stand down. If worse comes to worse, remove the tom mount and put some kind of plate on there that can accept an arm, a stand, whatever you conceive. That's the only difficult part. The rest is a piece of cake.
  #12
Old 04-14-2010
cjmnash cjmnash is offline
Newbie
cjmnash is on a distinguished road
or this...super simple & sounds great. (any speaker will do). bare wire -> 1/4" male -> DI -> mic pre. yummy.
chris mara
nashville, tn
www.welcometo1979.com
Bookmarks
Sub $100 kick mic (backup to main kick) nuemes Microphones 1 10-26-2006 13:11
Acoustic Kick that sounds like a 808 Sub Kick... GamezBond Drums and Percussion 18 06-28-2006 04:11
Noise Reduction DIY >not gated< DIY? orson198305 The Rack 12 06-21-2006 17:54
get a kick sound without a kick mic? bilibilek Drums and Percussion 11 05-01-2003 16:21
Any way to replace audio kick track with kick samples in sonar? Uladine Cakewalk / Sonar Forum 1 04-17-2002 11:06
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1995-2010 Audiofanzine except where noted. All Rights Reserved.
