Old 05-21-2001
Brad's Avatar
Brad Brad is offline
Back Door Conquistador
Brad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond repute
S/PDIF splitters or Y cables. Do they exist?
Curious if anyone knows if a SPDIF Y connector exists? My stand alone CD-R burner has one SPDIF in and I would like to hook up two sources without having to pull everything out of my rack to make changes between the two.
Any help appreciated!
Brad
Old 05-21-2001
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
http://www.derossi.com/hometech/video/splitters.html
Would this work?
Old 05-21-2001
drstawl's Avatar
drstawl drstawl is offline
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
Cool
Nope- those are all a different kind of coax jack. RCA not Composite Video- although the impedance of the whole cable is spec'd out the same as video cable (S-Video that also use the RCA ends): 75 ohms.
>This can cause variations of the insertion loss for each output
OUCH! that sound rather painful!
I leave two S/PDIF cables plugged into GINA all the time and just move the other ends of the cables when I need a different source or destination. If you're doing a lot of this I suggest a gold-plated plug on your S/PDIF cables.
An A/B switch that you wire up yourself would probably do the trick.
Old 05-21-2001
Gidge's Avatar
Lapdance Test Dummy
Cool
http://www.core-sound.com/custom-cables.html
These guys claim to make custom cables.....
