003+ with mbox 2 help?
So I just upgraded from an mbox 2 to a 003 rack+. I am trying to figure out how, or if i can, to use both interfaces at once, giving me 10 XLR inputs. Is the answer to connect the two via S/PDIF?
I am a bit lost, so any help would be appreciated. |
hmmm im not sure but try hooking both up, then go to SETUP>HARDWARE and see if the mbox shows up for spidif
My Band: Aqueous - www.aqueousband.com |
well, the mbox is there. but i believe it's there as a usb interface. i have spdif selected as the optical format for the 003, and i have spdif selected as the clock source for the mbox. i'm not sure if that's how i should have it.
in the I/O setup, it just shows the 003. my spdif paths show up as inactive, but i really don't know anything at all about spdif or how i should have this set up, or even if the way to do it would be through spdif. it seems that you can only have one active interface, right? so even if i am able to get the mbox inputs working via spdif, i won't have any of the playback on the mbox. i'll call digidesign in the morning. i was just seeing if anyone had a quick answer over the weekend. |
it doesn't work like that. you can only use one or the other
Alright, so, for anyone who might have this same question someday, I just talked with Digidesign. They were super knowledgeable and helpful.
The mbox 2 does not feed constant output from the pres to spdif. The mbox 2 pro does. It's the only member of the mbox family that does. So, in the case of the mbox 2, I can use my inputs, iffffff I'm routing it through a session on another computer, telling the inputs to output to spdif. As I have PT on my laptop, that would be no problem. It's not the greatest solution ever, but if I ever needed 2 more inputs, it'll work. |
rival studios |
to the OP: really though if i were you i would try to sell the mbox 2 and use the funds to finance an ADAT based 8 channel pre/converter. you'd get more channels and preamps all at the same time. that is of course unless you still need the mbox2 for some reason. don't let the debbie downers push you away from protools LE if it's where you want to be. it definitly has it's pluses. |
i am definitely happy with 8 pres instead of 2 for now. i was just seeing if i could get the bonus 2 running at the same time.
i still use the mbox for quick mobile stuff. and if i need to upgrade in the future i'll get another pre and connect via ADAT. LE definitely works for me at the moment. ![]() thanks guys. |
| for vocal recording mbox usb or mbox firewire? | candelamusic | Newbies | 4 | 03-04-2009 14:23 |
| for vocal recording, mbox usb or mbox firewire? | candelamusic | Pro Tools Forum | 4 | 03-04-2009 14:17 |
| Mbox 2 vs. Mbox 2 mini vs. Apogee Duet | MusicJoshua | Other Equipment and Reviews | 3 | 11-10-2008 08:26 |
| 003 | boogle | Digital Recording & Computers | 2 | 03-31-2007 23:48 |
| Mbox 2 vs. Mbox 2 Pro (USB 1.1 question) | pisces7378 | Digital Recording & Computers | 1 | 10-09-2006 23:02 |
