Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 03-19-2009
notredamer0789's Avatar
notredamer0789 notredamer0789 is offline
Senior Member
notredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond reputenotredamer0789 has a reputation beyond repute
How exactly does HD work?
Hi there everyone! I am an avid "LE" engineer and use it in my studio EVERY day! I love Pro Tools and after trying many different things have made it my primary DAW along with my 002 and various other outboard interfaces, comps, pres, and so on. I feel like an idiot asking this seeing as how I have been in several HD studios, but my question is... HOW EXACTLY DOES HD WORK? I know it's not as simple as installing PT on your pc (mac in my case) hooking up an interface via firewire and GETTIN' TO IT! I know you have to have I/O's, HD Cards, Different Software (Obviously lol), and other things... I just never really figured out how it works and how you are able to use ANY board (analog or digital) to mix with and run it! SO CONFUSING TO ME! Please someone help me out
Thanks alot!
Cory
CHASEProduction Studios
Old 03-20-2009
pezking pezking is offline
Force of Nature
pezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond repute
OK so that's a rather broad question, but I'll try to answer it concisely with the basics.
With Pro Tools HD, a PCI or PCIe card is required within the host machine. This is called the Pro Tools HD Core Card. This card carries out the bulk of the processing on the audio, including plug-ins. It is possible to add extra cards. These are called HD Accel cards (formerly HD Process cards) and supplement the core card. Therefore, more cards = more processing power. Typically systems are expanded to include up to 3 cards (this is called HD3) but somtimes higher numbers of cards are used, usually via an expansion chassis.
Each card supports a maximum I/O of 32 channels (across two interfaces). So you can see that with an HD3 system, you could have a maximum I/O count of 96. Each card also has 9 DSP chips and can support sample rates of up to 192KHz.
In addition to the card, an interface is required. There are 4 interfaces available from Digidesign: the 96 i/o, the 96i i/o, the 192 digital i/o and the 192 i/o. Each one of these interfaces supports up to a maximum of 16 simultaneous i/o, and provides different types of connection as well as sample rates. They connect to the Core/Accel cards using the Digilink connection - a type of serial data transmission. Where two interfaces are used with one card, the first interface connects directly to the card, and the second is connected to the other interface, essentially daisy chaining them.
The only other thing needed to fire the system up is the iLok. This is a USB dongle which would contain the license to run Pro Tools HD as well as some additionaly plug-ins.
So there you have it, that's the basic jist of Pro Tools HD.
Just as a reference to how powerful it is, one card can run these plugins simultaneously:
42 x d3 compressor, 43 x URS Neve 1081 EQ, 27 x Rennaisance EQ 6 Band, 12 x Sony Oxford Compressor/Limiter, 24 x Sony Oxford 5 Band EQ, 5 x Line 6 Amp Farm.
The only other thing to say, in direct response to your post, is that you can use any outboard/mixer/equipment if you can connect it to one of the interfaces via analoge connection, AES/EBU, ADAT, TDIF or SPDIF.
It is also worth noting that Apogee have reverse engineered some of Digidesign's interfaces so that they can provide an interface for Pro Tools HD with their converters.
Old 03-20-2009
Senior Member
Thanks alot! That really does help. It's SOOO much different than simple LE systems haha. I just never knew how you could hook an analog board up to Pro Tools. I looked at the back of an interface and didn't see anything I thought would hook up esp to be able to multi track. And buddy is HD expensive!!! Lol thanks again!
Old 03-20-2009
Force of Nature
It is comparitively expensive however it is a pretty rock solid format, and it's quite powerful.
The connections on the rear are in various formats:
1/4" TRS for Analogue (on 96 i/o and 96i i/o)
XLR for AES/EBU (all except 96i i/o)
RCA for SPDIF (all)
Optical for ADAT (all except 96i i/o)
DB25 for analogue on 192 i/o
DB25 for AES/EBU and TDIF (on 192 i/o and 192i i/o)
Hope that helps...
I think HD is still pretty simple, you just need a core card and interface...
Old 03-20-2009
Senior Member
Ah gotcha lol and TONS of extra cash right That really helps, thank you! About the pc though... will Core Cards or Accel Cards work with any pc or does it have to be a pretty fast machine? And do they install in the pc like a... say... firewire card would?
Tell me if this will work Jtrain42 Recording Techniques 23 08-13-2003 22:06
how does it work LEONOEL DJ & Hip Hop Production 4 01-29-2002 00:09
How does it work??? Bobcat102122 MIDI Mania 7 07-01-2001 14:10
