Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 03-17-2009
pinkieandtherev pinkieandtherev is offline
Junior Member
pinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond reputepinkieandtherev has a reputation beyond repute
Buzz in the middle tom
OK, i'm stumped. I've read stuff on tuning, and tried everything I can think of...
My center tom is buzzing like crazy. The buzz decays quickly...it almost sounds like striking the head is causing some of the hardware on the drum itself to vibrate. I can't figure out what to try to dampen.
I had left this drum off the kit for awhile because I'd broken the head. I played the kit as a four-piece for awhile. When it came time to record again though, I needed the five-piece back. Since I put the new head on, I've yet to get the sound I want, although the buzz didn't really bother me until it came time to put the mics to it.
Any suggestions? Short of a new kit or a complete new head pack, both of which would be nice...
Old 03-18-2009
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Um...have you taken a look inside the drum???
You'll notice that all the hardware is held in place, from the inside, with screws...Go figure. You might want to take a drum head off and tighten all those screws.
Just a hunch.
Old 03-18-2009
Junior Member
great idea...i'll try that first thing this morning.
OK....first off, it would help if I TUNED the drum to the proper tone...tune that head up tight enough, and boom...less resonance and no buzz. Tune the others up to match the new tone, and yay...it works
now to haul those office panels in tomorrow. wasn't going to do it today and just have to tear it down tonight for church.
Old 03-19-2009
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
Rami is right.
I will also add that often the lug hardware is to blame.
If it is not some internal (to the drum) screw or washer, it can also be the spring inside the floating nut element of the lug. (assuming you dont have tube lugs or solid lugs)
I used to have to pull my old lugs and put a foam ear plug inside the spring of the lug.
Quiets them down nicely.
It is also not uncommon for the heads to buzz a little if it is a 2 ply or hydraulic that is old and starting to seperate...particularly if it is tuned really loose.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 03-19-2009
MidiPunk's Avatar
MidiPunk MidiPunk is offline
Drunken Heckler
MidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond repute
Could be the stand/rack the drum is mounted on too.
...Or uneven bearing edge.
Old 04-09-2009
tddrummer tddrummer is offline
tddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond repute
Dont play it..everyone else is..lol
Old 04-09-2009
8bus 8bus is offline
Junior Member
8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute
I was in a studio one time recording drum part for a guy and tom,s where ringing, so they found-out that it was the hardware so they took all of the lugs off and stuffed them with cotton balls, the ringing was gone.
Old 04-10-2009
The549 The549 is offline
a hack
The549 will become famous soon enoughThe549 will become famous soon enough
There can be rattling things inside lugs, the lugs/screws themselves, or worst case is a poorly tuned/uneven bearing edge, which can cause a head to sizzle against the wood with certain (or any) kinds of tuning.
High tom --> Snare buzz gbondo9 Drums and Percussion 4 07-03-2007 16:54
Tom Stand vs Tom mount tilinmyowngrave Drums and Percussion 5 10-20-2005 15:04
tom micing problem, cant kill buzz perforateme Microphones 6 06-20-2004 21:26
tom tom ringing while the rest of the kit is being played kristian Recording Techniques 20 11-01-2001 14:16
Buzz? Make the buzz stop, please. ClintJCL Analog Only 2 05-30-2000 15:20
