Old 03-14-2009
bjbradley bjbradley is offline
Newbie
bjbradley is on a distinguished road
how to eliminate pops and clicks
Hello, I am a new user. I use 2 large diaphragm condenser mikes through my Aphex 207 tube pre and into LINE IN 3/4 in back of the PreSonus Firebox 6x8. I keep my levels just below the red in the Aphex and have adjusted my levels in Cubase essential 4. I have lowered my firebox mixer 2-3 DB and I've turned off all the suggestd internet connects/firewall soundcard etc. I have a dual core processor on my laptop, running at 2+ Ghz. I still have clicks and pops. Any suggestions? Thanks so much
Old 03-14-2009
buckkillr8's Avatar
buckkillr8 buckkillr8 is online now
David Gilmour's clone
buckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond repute
what's your latency settings? I see you're using Presonus, do you have the ASIO4all drivers isntalled? Presonus along with most interfaces like to use ASIO drivers for the lowest latency.
Go here and download the ASIO4All program. Install it and make sure to check the box for "offline" settings or something like that so that you can get the ASIO control panel from the start menu.
www.ASIO4All.com
My Gear
Old 03-14-2009
Newbie
clicks and pops question
[QUOTE=buckkillr8;3115323]what's your latency settings? I see you're using Presonus, do you have the ASIO4all drivers isntalled? Presonus along with most interfaces like to use ASIO drivers for the lowest latency.
thanks so much, I will try that.
Old 03-14-2009
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Isn't there a real ASIO driver for the FireBox? If so, why use a hack like ASIO4All?
The pops may have to do with IRQ sharing between your FireWire interface and something else on the system. Audio devices are very sensitive to interrupt latency. Also, what FireWire chip does your laptop use? TI? NEC? Lucent? Something shady?
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 03-15-2009
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
That's probably the problem. You don't need to record that hot. Do a search on "Gain Staging".
Old 03-16-2009
Newbie
Rami
I found that when I increased my gain on the tube pre and lowered my cubase volume, the pops decreased. What do you make of that? thanks.
Old 03-16-2009
Newbie
pops and clicks saga
I am using Texas Inst. OHCI compliant firewire chip on my Dell studio laptop. Any ideas?
Old 03-16-2009
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Clicks and pops are usually signs that your drive is not keeping up with the data flow.
Are you recording to the internal drive???
You SHOULD always record to a secondary dedicated drive.... Since you are using firewire you should have a drive on that chain to record to.
Old 03-16-2009
Newbie
I have a dual core processor. which runs at 2.16 Mghz I thought the dual core processor would give me this secondary drive idea. Is that correct?
Gain on the tube pre is betwn -12DB and -18DB and My gain is WAY down on the Cubase input. So this should not be presenting a problem. appreciate your help. thanks.
Old 03-16-2009
buckkillr8's Avatar
No a second drive is just that. A second Hard Drive.
My Gear
clicks and pops be gone jesushimself Digital Recording & Computers 1 08-31-2004 07:43
Clicks and pops the edzell Cool Edit Pro / Adobe Audition Forum 6 07-08-2004 22:17
Pops 'n Clicks Editor Newbies 3 11-28-2003 16:15
Clicks and pops josesequeira Digital Recording & Computers 3 12-09-2002 16:48
Clicks and Pops dunkatie Digital Recording & Computers 2 06-10-2002 05:39
