Old 03-07-2009
BentRabbit's Avatar
BentRabbit BentRabbit is offline
Drumb & Drumber
BentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond repute
.38 rule
So...
Does the .38 rule also apply vertically?
In my 30x17 basement studio, I'm doing my mixing on the back wall, but using the 17' width and setting up gobos at around 9' (see pic)
I pulled my desk 6.4' into the mixing area to come into the .38 realm... I'm noticing now tho (with my new Adams) if I duck my head closer to the mixer, I'm getting a sweeter spot than just sitting up in my chair... The .38 rule applied to 7 foot ceilings = 2.66 feet... Roughly the distance from the floor to my mixer...
So... In order to get to the sweetest spot, do I gotta mix with my head down all the time?
I am thinking about moving the desk to the end of the room (where the keyboards are) and using the full room, but I'm not sure if I would gain enough to warrant the moving of equipment...
So, to all studio and acoustic gurus... HELP!!!
If you don't hear what the mix is telling you, you shouldn't be working on it in the first place. - John Scrip, Massive Mastering
Myspace Page
Old 03-07-2009
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Yes, .38 special rules! Hold on loosely, but don't let go...
http://www.youtube.com/watch?v=xMxqPRdR36I
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 03-07-2009
CIRO's Avatar
CIRO CIRO is offline
Capituīs brother
CIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond repute
Hi, Bent.
Iīm not (near) an acoustic guru, but let me try
IMO/E, the rule applies to height too.
First,you should avoid your / monitors position halfway (or near, letīs say, between 42-50%) ceiling/flor - a bad place because puts everything in a null of first (height) mode (~82hz) and a peak of second (~164hz).In teory, at least .
As itīs impossible to sit even near the .38 height "floor --->ceiling", did you tried the .38 "ceiling--->floor"? (not so hard)
You can try to do the same with monitors,it should work (hey, I never tried the "ceiling---> floor" 38 percent because my height is almost 9',then Iīm near (monitors too) the .38% "floor ---> ceiling".Nor "exactly", but "near".
Ciro
Old 03-07-2009
BentRabbit's Avatar
Drumb & Drumber
You've been waiting all year for someone to ask this haven't you...?
Myspace Page
Old 03-07-2009
BentRabbit's Avatar
Drumb & Drumber
Originally Posted by CIRO View Post
Hi, Bent.
Ciro
Thanx Ciro...
I got some serious chewing to do now in regards to my space...
Myspace Page
One mic to rule them all? tojo Microphones 4 08-12-2007 22:45
One mic to rule them all? tojo Microphones 2 08-12-2007 11:01
Copyright Đ 1995-2008 Audiofanzine except where noted. All Rights Reserved.
