Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-04-2009
shizzane shizzane is offline
Newbie
shizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond reputeshizzane has a reputation beyond repute
Cuebase LE4 - Reverb/Tracks
Hey guys,
My issue is:
I recorded a song with 2 vocals. I inserted reverb (Lexicon...) to each vocal and it sounded just the way I wanted.
I then recorded a new song with 3 vocals. In attempting to do the same, when I added reverb to the 3rd vocal, the other 2 vocals would not play back with the reverb meaning the reverb was still assigned to the track but was missing in playback.
My set up is:
Lexicon Omega
Cuebase LE 4
Is this a Cuebase LE 4 limitation? Again, I'm new so I apologize if this is a very simple thing and I overlooked it.
Thanks for any comments or suggestions.
Old 03-18-2009
drinkytheclown drinkytheclown is offline
Registered User
drinkytheclown is on a distinguished road
you say you 'inserted' it? vocal reverb aint an insert. shouldn't be on that side of the chain. you need to set it as a global send, set the global level, then assign each track to send it and what level for the individual power. setting it as an insert will run the effect 3x as much so depending on the reverb, yeah, it might not keep up. placing it as a send only runs it once and passes as many channels as you want. for vocals, compression exp/gate should be an insert side. reverb, echo, and eq should usally be as a send on the downstream side.
Cuebase dropouts dad3rdx Cubase User Forum 1 08-31-2006 20:31
BR 1180 reverb goes to all tracks universally? Why? undrgrnd studio Roland, Boss, VS Series Forum 0 12-21-2004 10:52
How do I use my 01v reverb on dry tracks in cubase? boze MP3 Mixing Clinic 4 03-29-2003 19:01
Applying External Reverb to CEP tracks dobro Cool Edit Pro / Adobe Audition Forum 2 10-27-2000 09:33
cuebase as mtc supper Cubase User Forum 0 09-02-2000 13:51
