Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 03-04-2009
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
protools mbox, only 2 inputs?
Could'nt an mbox,mbox 2 to be specific, accept 16 inputs at a time when used with something like a Mackie 1640 firewire mixer. I read somewhere here that there inputs are limited but I am not sure if that is due to the mbox only having 2 inputs or more a software,protools le thing. Anyone know?
People always seem to embrace the future then long for the past
Old 03-04-2009
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
it's both
Pro Tools LE only allows one interface at a time (and their own brand of interfaces only)...while the Mbox 2 is a USB 1.1 device which simply can't handle the bandwidth of 16 I/O
www.redlabaudio.com
Old 03-04-2009
deejaytrixx deejaytrixx is offline
Analog? What's that?
deejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond reputedeejaytrixx has a reputation beyond repute
yup what he said..but of course you can expand the number of i/o using the s/pdif
Old 03-04-2009
pezking pezking is offline
Force of Nature
pezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond repute
not on the original mbox you can't.
it's either the anaologue or the digital, not both
Old 03-04-2009
Are you referring to my post? If you are the original Mbox comes with a S/PDIF I/O. If you connect that to a A/D converter that also has S/PDIF you can increase the number of I/O. I've done it myself and seen it done many times...The most problems you might have is world clock, which I have never actually seen been a problem
Edit:
Of course this depends on how you want to use your system. By the increase in the number of I/O, I am referring to how many analog tracks that can be recorded simulatenoulsy by adding another device that is S/PDIF capable and still staying in the Mbox price range.
Old 03-04-2009
Force of Nature
Edit:
Yes I was referring to your post.
With the original Mbox, you could only use 2 channels I/O at a time. Either the analogue or the digital.
With the Mbox 2 you can have 4 simultaneous ins, 2 analogue and 2 digital. However you could only have 2 channels of output but across the digital and analogue. I.e. the outputs are mirrored. So Left Analogue=Left Digital and Right Analogue=Right Digital.
Old 03-04-2009
I understand what you're saying, but this doesn't exactly deal with the point I'm trying to make. He can still use for instance, an A/D converter with lets say, 16 I/O's and presumably extend his I/O count to 17 with the original Mbox.
I believe you are referring to the actual Mbox unit not being able to accept more than two inputs on it's own, without a S/PDIF extension.
No doubt you are correct, but S/PDIF offers you a workable work around.
Old 03-04-2009
no you can't have 16 I/O with the Mbox. First off, S/PDIF is limited by it's own design to a max of a four channel protocol (although the most you more commonly see is only two channel devices). Second, again, the USB 1.1 protocol also limits the amount of simultaneous I/O you can have with an interface. Since the Mbox is a USB 1.1 interface, it only allows you two channels. The Mbox 2 came out and pushed the USB to allow 4 channels. I think you'll be hard pressed to find a USB interface that allows much more. The max I've seen is 6 channels of I/O simultaneously on one. Most companies use firewire for more than that.
www.redlabaudio.com
Old 03-05-2009
Force of Nature
Further to what Benny has said, even with an SPDIF converter, you can only have 2 channels of input and output for the Mbox.
In addition to that, as he pointed out SPDIF tends to be a stereo connection.
SPDIF with 4 channels? Can you point me in the direction of some info on this? I didn't know it existed. Are there any devices that support it?
Old 03-05-2009
jmorris's Avatar
Thanks everyone. I was aware of the " have to have a protools/m audio piece of hardware" thing but I wondered if there is a piece of protools hardware connected, would it then allow a non protools piece of hardware in. Figured not. Thats dumb!But it is what it is..
Old 03-05-2009
dude, I'm not saying that you will be able to record onto 16 individual tracks into pro tools, I'm saying that if you wanted to, you can use S/PDIF as an extender..that is y I said it DEPENDS on how you want to use your system..It's the same as if I take an analogue board with 48 inputs, run it into one channel of my mbox, and record. Will it be one track in PT, of course! but can I record more than one track at a time..sure..
And if you think this is a crazy way of working, that argument definitely has merits. But do some dudes do it, obviously.
It has obvious advantages for ppl who are sure of what they are recording and just want a stereo mix from many mono takes....like a drum set for instance..
  #12
Old 03-05-2009
when you are talking about I/O count people usually assume you mean simultaneous I/O. When you said "He can still use for instance, an A/D converter with lets say, 16 I/O's and presumably extend his I/O count to 17 with the original Mbox," we all assumed you were meaning simultaneous I/O. Because I=input and O=output. So extending the I/O would mean adding more in and outputs to the original Mbox. Which is not possible.
Yes, you can take a 36,549 channel mixer, sum it down to two channels and kick those out S/PDIF and into the Mbox....but the resulting input is STILL only two channels. It'd be the same thing if you had 36,549 musicians in a room all playing at the same time into two microphones that were plugged into the Mbox. You only get two channels.
I think we were just confused as to what you were getting at.
an example of a multichannel S/PDIF device you might be familiar with, your consumer DVD player. I have mine hooked up to my receiver via S/PDIF. The multichannel DTS codec is transferred to my surround receiver and decoded so I can have 5.1
I'm not aware of any recording industry devices that allow you to transfer 4 channels though...but I think it's very possible one could be out there. The channel status bit in the S/PDIF protocol is what determines how many channels of audio is to be used. Two channels is just the most common usage.
http://en.wikipedia.org/wiki/SPDIF
http://www.minidisc.org/spdif_c_channel.html
www.redlabaudio.com
  #13
Old 03-05-2009
Force of Nature
I guess what I don't get is what difference it makes using it with SPDIF or analogue. I also didn't really make sense of what you wrote previously.
Unfortunately those links don't really answer my question (or at least what I meant )
As far as I knew the 4 channel capability was actually redundant and was added, during SPDIFs inception, as a solution for quadrophonic sound as Sony and Philips still thought it was going to take off.
From what I remember of DTS, it's an encoding of multiple channels, to two, so that the same signal can be replayed whether it has been decoded or not. So it's like a pseudo multi-channel coding, rather than providing multiple discreet channels.
I do hope that makes sense
How to get more inputs with SPDIF and Mbox 2 blkdog7 Pro Tools Forum 5 01-19-2008 13:05
MBox 2 - 4 inputs? inthenameof666 Newbies 2 12-11-2007 13:35
Humming sound when I use phono inputs on Mbox 2 Pro James Tongham Pro Tools Forum 4 10-24-2007 08:26
Protools v7.0 for Mbox 2 having problems with the protools 7.0 yunga123 Digital Recording & Computers 3 10-20-2006 19:05
Need reccomendations on better inputs for my computer (aka mbox, firebox, etc) jndietz Digital Recording & Computers 5 01-03-2006 15:02
