Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 03-01-2009
nate_dennis's Avatar
nate_dennis nate_dennis is offline
Infinite Newb
nate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond repute
Stupid Direct Recording Question
Ok, so I'm new to direct recording of electric guitars. If I run a guitar through a MFX pedal with Amp Modeler do I need to put a D.I. in between the MFX and the mixer? I'm sure this is a stupid question, but I really have no clue. Thanks a lot guys.
Old 03-02-2009
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
If you are talking about a passive DI that is just a transformer, and you are not trying to drive cables that are 30 or 40 or more feet long, or if you are not working in an extremely RF noisy environment, then no, there's no reason to use it unless you have a ground loop you need to break. If you need tone shaping and/or signal boost and you have a DI that does that, then maybe.
If something upstream from your mixer also plugs into AC, you may have a ground loop (you'll hear the 60Hz hum if that happens), and a DI will let you disconnect the hi-Z shield from the ground of the low-Z input.
Gordon in Austin
http://www.crystalflavola.com
Old 03-02-2009
Infinite Newb
Thanks so much! I was about to start connecting the MFX through a DI then in. I appreciate the help.
question about direct recording woody777 Newbies 1 11-28-2007 22:44
Stupid Recording Chain Question: pre->mixer? bpr103 The Rack 10 11-23-2005 16:17
414mkII Direct Recording question JD20 TASCAM User Forum 3 11-01-2005 09:25
Stupid question about effectracks and multichannel recording _ronin75_ Newbies 4 06-12-2003 16:25
direct recording question brandon.w Recording Techniques 2 02-08-2002 00:53
