Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 03-01-2009
tom18222 tom18222 is offline
yes
tom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond repute
sonic maximizer question
are these things good in fx loops? i have heard that they are great and that they suck.
the thing is, im not sure yet. i just ordered a tc electronic g major. theres a possibility that i may encounter some "tone suck" through the fx loop of my dual recto because of an impediance mismatch.
i dont know because i dont have it yet, but im just planning ahead.
Old 03-01-2009
ocnor's Avatar
ocnor ocnor is offline
Lord Of The Thighs
ocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond repute
The Sonic Maximizer which is the most notorious tone sucker on the planet will not fix an impedance mismatch. Using one of those pieces of junk would be like trying to put out a fire with gasoline.
Old 03-01-2009
yes
well can you recommend a good buffer for a rackmount setup? i want no pedals, i have a midi controller that will control the entire rig.
Old 03-01-2009
Tadpui Tadpui is offline
Force of Nature
Tadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond repute
You'll have to look up the input and output impedance of your G-Major unit, as well as the input and output impedance of your effects loop on your Mesa. Honestly, I don't think that its going to be a big deal. Hook it all up and if you notice any problems or tone suck, THEN start asking these questions. There will only be a problem if you hear a problem. It's probably a bad idea to just assume that you're going to have problems before you even hook up your new gear and actually play through it.
________________________________________________________________
Everyone's a voyeur, they're watching me watch them watch me right now
Old 03-01-2009
yes
right, just tryin to be prepared
Old 03-01-2009
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
The BBE is not going to help because impedance mismatches (assuming you actually endo up having that problem) tend to make things sound thinner. The BBE will only make it sound thinner and brighter, thus adding to the problem.
I have never had much of a problems putting stuff in Mesa effects loops that will pass an uncolored signal. If the G-Major has a 'sound', your guitar tone will be filtered through the G-majors sound.
The best thing to do would be to run the effects at 100% wet and mix them with the 'mix' control on the back of the head. Then, your guitar tone will be intact and the only thing that will sound like the g-major will be the effects.
That should be a parallel effects loop you have there...
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 03-02-2009
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
The BBE needs to be used carefully, minimally and infrequently unless it's THE SOUND you've always wanted.
It's one of the spanners you only occasionally reach for and then usually put back because it often doesn't fit.
Cheers
rayC
soundclick, unearthed, mspace & utub
Old 03-02-2009
yes
whats the best kind of cables to use in an fx loop? short instrument? stereo 1/4"?
Old 03-02-2009
Farview's Avatar
Effects loops in guitar amps are not balanced. You would use a normal TS cable. (instrument cable)
Jay Walsh
FS. BBE Sonic Maximizer 362 Myriad_Rocker Free Ads for Music / Recording Equipment 1 07-26-2006 07:46
Sonic Maximizer question proclaim The Rack 69 03-18-2006 09:03
Sonic Maximizer? ghetto3jon The Rack 8 11-10-2002 12:30
BBE Sonic Maximizer SLuiCe Cakewalk / Sonar Forum 4 07-26-2002 16:21
BBE sonic maximizer Rolland Recording Techniques 6 04-21-2000 12:15
